2005 Nissan Altima Alarm/Remote Start/Stereo Wiring
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 2005 Nissan Altima Alarm/Remote Start/Stereo Wiring (
Topic Closed)
Welcome Guest :)
Posted: November 11, 2007 at 9:34 PM / IP Logged
do anyone have the wiring information for 05 altima. Need to install an alarm.
Posted: November 12, 2007 at 9:03 AM / IP Logged
Audiovox Lists:
#506757: 2005 NISSAN ALTIMA 4DR SEDAN WITH 2.5L ENGINE AND BOSE® AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery YELLOW /GREEN (+) RADIO HARNESS
Accesory PURPLE (+) RADIO HARNESS
Ground CHASSIS (-) CHASSIS GROUND
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED / BLUE (+) RADIO HARNESS
Dimmer RED / YELLOW (+) RADIO HARNESS
Power Antenna GREEN (+) RADIO HARNESS
Amp Turn On GREEN / WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) BLUE/RED
RF Speaker (+) WHITE/ BLACK
RF Speaker (-) BLUE/BLACK
LR Speaker (+) GREEN/ YELLOW
LR Speaker (-) BLACK / YELLOW
RR Speaker (+) BLUE
RR Speaker (-) RED
Amp Location UNDER REAR DECK IN TRUNK
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Battery GREEN (+) AT IGNITION HARNESS
Ignition 1 BLACK/ RED (+) AT IGNITION HARNESS
Starter 1 BLACK/ RED (+) AT IGNITION HARNESS
All Door Trigger USE LATCH WIRES (-) DIODE ISOLATE
PIN #32
Domelight Super RED (-) BCM PIN 63
PIN #32
LF Latch LIGHT BLUE (-) BCM PIN 47
WHEN INSTALLING A REMOTE START IN AN ALTIMA WITH AUTO-HEALIGHTS, YOU MUST PULSE THIS WIRE GROUND WHEN THE REMOTE START SHUTS DOWN TO KEEP THE HEADLIGHTS FROM STAYING ON.
RF Latch PINK/BLUE (-) BCM PIN 12
PIN #10
LR Latch RED / BLACK (-) BCM PIN 48
PIN #11 - BOTH REAR DOORS ARE MONITORED BY THIS WIRE.
RR Latch RED / WHITE (-) BCM PIN 13
Trunk Trigger PURPLE / WHITE (-) BCM PIN 42
PIN #18
Hood Trigger YELLOW/BLACK (-) AT POWER DISTRIBUTION CENTER UNDER HOOD
PIN #51
Alarm Disarm WHITE/ BLUE (-) IN THE DRIVERS DOOR AT DOOR MODULE PIN 4
SINGLE PULSE WILL DISARM THE ALARM AND A DOUBLE PULSE WILL UNLOCK THE DOORS.
Alarm Arm PINK/BLUE (-) IN THE DRIVERS DOOR AT DOOR MODULE PIN 5
PIN #59 - THIS WIRE RESTS AT +5V, USE A RELAY TO PULSE THIS WIRE TO PREVENT A +12V SIGNAL FROM BEING APPLIED BY SOME ALARM OR KEYLESS ENTRY SYSTEMS.
Parking Lights RED / BLUE (+) DRIVERS SILL PLATE
ALSO AT DIMMER SWITCH LEFT SIDE OF STEERING COLIMN ON DASH.
Convenience
Headlights-Lo BLUE (LEFT), RED / YELLOW (RIGHT) (+) GRAY 16 PIN CONNECTOR AT IPDM E/R
PIN #24 & #22 - USE BOTH WIRES AND DIODE ISOLATE THEM.
Headlights-Hi BLUE/WHITE & GREEN (+) AT POWER DISTRIBUTION CENTER UNDER HOOD
PIN #21 & #27 - USE BOTH WIRES AND DIODE ISOLATE THEM.
LF Pk Lt Bulb RED / BLUE (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb RED / BLUE (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb RED / BLUE (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb RED / BLUE (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights GREEN/ RED (-) BCM PIN 29
PIN #61
LF Hazrd Bulb GREEN/ BLACK (+) AT FRONT LEFT DIRECTIONAL LIGHT
WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #22
RF Hazrd Bulb GREEN/ YELLOW (+) AT FRONT RIGHT DIRECTIONAL LIGHT
WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #21
LR Hazrd Bulb GREEN/ BLACK (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb GREEN/ YELLOW (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo BLUE (+) GRAY 16 PIN CONNECTOR AT IPDM E/R
PIN #31
Wipers-Hi BLUE/BLACK (+) GRAY 16 PIN CONNECTOR AT IPDM E/R
PIN #30
Parking Brake GREEN (-) AT PARKING BRAKE SWITCH
Trnk Release RED / BLACK (-) BCM PIN 30
MAY ALSO BE BLUE/RED
Remote Start
Ignition 2 BLACK/ RED (+) IGNITION SWITCH HARNESS
Accessory 1 RED (+) AT IGNITION HARNESS
Accessory 2 WHITE/ BLUE (+) AT IGNITION HARNESS
Starter 2 BLACK / YELLOW (+) AT IGNITION HARNESS
Anti-Theft Type NISSAN NVIS® VEHICLE IMMOBILIZER
Anti-Theft Descript TRANSPONDER
Key Sense BLACK/ RED (-) AT IGNITION HARNESS
ALSO AT BCM PIN 37
Neutral Safety GREEN/ RED (-) AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL
PIN #43 - WILL BE GREEN/ RED ON AUTOMATIC TRANSMISSION MODELS AND GREEN / WHITE ON MANUAL TRANSMISSION MODELS.
Tachometer USE INJECTOR OR COIL (AC) USE UNCOMMON WIRE ON ANY COIL OR INJECTOR
THE VEHICLE TACHOMETER SIGNAL IS SENT THROUGH A DATABUS LINE - YOU MUST USE A CRANKSHAFT OR CAMSHAFT POSITION SENSOR OR A FUEL INJECTOR SIGNAL WIRE.
Crankshaft Sensor WHITE (AC) AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL
PIN #71
Camshaft Sensor WHITE (AC) AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL
PIN #62
Speed Sense PINK
MAY ALSO BE BLACK. THIS IS ON THE MIDLINE AND BOSE RADIO VEHICLES ONLY. VEHICLES WITHOUT 5 SPEED AUTOMATIC TRANSMISSION CAN USE A BLUE / YELLOW BEHIND INSTRUMENT CLUSTER.
Brake Lights RED / GREEN (+) AT BRAKE SWITCH
Reverse Lights GREEN / WHITE (+) DRIVERS SILL PLATE
Horn GREEN / WHITE (-) AT STEERING COLUMN HARNESS
Anti Theft RX BLUE/RED (DATA) AT IMMOBILIZER CONTROL UNIT IN STEERING COLUMN
Anti Theft TX WHITE/ BLUE (+) AT IMMOBILIZER CONTROL UNIT IN STEERING COLUMN
Modules
WIRE LOCATION
Module 1 BCM IS LOCATED TO THE RIGHT OF THE FUSE BOX
Module 2 IPDM E/R (INTELLIGENT POWER DISTRIBUTION MODULE ENGINE ROOM) IS UNDER HOOD BEHIND PASSENGERS HEADLIGHT.
Doorlocks/Windows
Power Unlock PINK (-) BCM PIN 46
THIS WIRE IS USED FOR VEHICLES WITH LEFT FRONT ANTI PINCH SYSTEM ONLY. ON VEHICLES WIYH BOTH FRONT WINDOW ANTI PINCH USE FACTORY ARM/DISARM WIRES FOR LOCK/UNLOCK.
PowerLock BROWN (-) BCM PIN 45
TEST WITH THE KEY IN THE DRIVERS DOOR. THIS WIRE IS USED FOR VEHICLES WITH LEFT FRONT ANTI PINCH SYSTEM ONLY. ON VEHICLES WIYH BOTH FRONT WINDOW ANTI PINCH USE FACTORY ARM/DISARM WIRES FOR LOCK/UNLOCK.
2 Step Unlock GREEN / WHITE (+) AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL
PIN #23
Driver Mtr Unlock GREEN/ RED (REV) BCM PIN 66
Driver Mtr Lock YELLOW/RED (REV) BCM PIN 65
Pas Mtr Unlock GREEN / WHITE (REV) BCM PIN 59
Pas Mtr Lock GREEN/ RED (+) AT MOTOR IN DOOR
LF Window Up BLUE/RED (REV) AT DRIVERS WINDOW SWITCH IN DOOR
LF Window Dn BLUE/WHITE (REV) AT DRIVERS WINDOW SWITCH IN DOOR
RF Window Up GREEN (REV) DRIVERS KICK PANEL
IF VEHICLE HAS AUTO UP/DOWN ON PASSENGERS FRONT WINDOW YOU MUST USE BLUE FOR UP AND GREEN/ BLACK FOR DOWN IN THE PASSENGERS DOOR.
RF Window Dn YELLOW (REV) DRIVERS KICK PANEL
LR Window Up PURPLE (REV) DRIVERS KICK PANEL
LR Window Dn BLUE (REV) DRIVERS KICK PANEL
RR Window Up RED / YELLOW (REV) DRIVERS KICK PANEL
RR Window Dn YELLOW/BLACK (REV) DRIVERS KICK PANEL
Sunroof Open ORANGE (+) AT SUNROOF SWITCH
THIS WIRE WILL EITHER CLOSE THE VENT POSITION OR SLIDE THE SUNROOF OPEN DEPENDING ON THE CURRENT STATE OF THE ROOF.
Sunroof Close BLUE/RED (+) AT SUNROOF SWITCH
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Saturday, April 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
