2009 toyota tacoma vss?
gfisher99
Posted: December 14, 2008 at 8:53 PM / IP Logged
Hey guys,
I have researched the heck out of this and I think Toyota made a change or something since the 2008 models.  I just installed a Pioneer Avic Z1 and tapped into the PURPLE / White wire at the ECM (2nd Plug up from the bottom.  Problem is, my head unit does not show any Speed Pulse values when I drive.
The pictures I have seen on other forums like Avic411, etc all show the ECM plug being White.  Mine is Black, and Im wondering if they changed the wiring config.  I have yet to see anyone install anything like this in a 2009 Tacoma.
Does anyone have any info on the VSS wire for a 2009?
Also, I saw on another post that if you vehicle had a factory deck with SCV, that the speed pulse wire would be in one of the factory harnesses.  If anyone knows where it is in there, it might be easier to get to to tap.
Any help is greatly appreciated!
Greg
Mike M2
Platinum - Posts: 2,652
Posted: December 15, 2008 at 5:34 PM / IP Logged
I've done a few of these trucks and always get it the same place. On the front of the fuse box/BCM there is a black 13 pin plug, pin 5, PURPLE / white....
Mike M2
Tech Manager
CS Dealer Services
gfisher99
Posted: December 15, 2008 at 11:29 PM / IP Logged
Where is this box?  The place I have seen others tap it is behind the glove box.  Its the second plug up from the bottom, plugged into the silver box on the far left.  Thats the one I tried to tap (PURPLE / white) with no success.  Seems like there might be more than 13 wires in that plug though.
Am I looking at the right place?
I would go count the wires right now, but Im out of town for work.  Back tomorrow night.
Please let me know?
I appreicate your help!
Greg
Mike M2
Posted: December 16, 2008 at 6:34 AM / IP Logged
The fuse box is located left of the steering column, behind the pocket. Remove the plastic panel under the drivers dash and you will see it....
Mike M2
Tech Manager
CS Dealer Services
gfisher99
Posted: December 18, 2008 at 6:48 PM / IP Logged
Awesome!
Hey Mike, you are my hero :)
Black Plug on front of fuse box, PURPLE / white is the one.  My Avic Z1 is happy now!
Thanks so much!
Greg
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
