in dash tv
justin02
Posted: November 25, 2012 at 11:25 PM / IP Logged
I am making a custom fiberglass dash and i have seen them with 19inch monitors in them. How is this done? using a computer monitor or a tv screen? and how is it hooked up to be able and watch dvds and stuff like that? any help in appreciated
Platinum - Posts: 13,725
Posted: November 26, 2012 at 10:27 AM / IP Logged
What are you using for a DVD player?
justin02
Posted: November 26, 2012 at 7:10 PM / IP Logged
thats what im asking. Idk how it is done. Using some sort of dvd player wired in or hooking a head unit to the monitor and running it that way. Is a computer moitor or a tv used and how is the tv wired in?
Mike M2
Platinum - Posts: 2,652
Posted: November 27, 2012 at 6:31 AM / IP Logged
Most new flat screen TV's give multiple inputs including a monitor input, plus they are cheaper.
Mike M2
Tech Manager
CS Dealer Services
justin02
Posted: November 27, 2012 at 12:57 PM / IP Logged
Ok thanks. So do you wire your DVD compatible head unit to the tv? And to get power to the tv is a converter just wired in?
soundnsecurity
Gold - Posts: 2,720
Posted: December 01, 2012 at 10:11 AM / IP Logged
it would be easier to buy a raw panel monitor that is meant for 12v applications instead of using a tv that will need an inverter.
after that you will need some sort of trim ring that you will use to mold into the fiberglass dash and this will create the opening for the monitor and mount the monitor from behind. if you use an actual tv then you need to take it apart and use the front of the case as the trim ring that you mold into the dash.
