dvd wiring diagram 04' sububan
asapaudiopro
Posted: February 11, 2004 at 10:18 PM / IP Logged
Looking for wiring diagram on the factory dvd player on a 04' chevy suburban.  It a panasonic piece.   I am looking to tap into the video signal to add more screens in the vehicle.  Anyone with info please forward to asapaudiopro@yahoo.com Thanks for your help.
ASAP Pro
sparkie
Platinum - Posts: 2,061
Posted: February 16, 2004 at 1:21 PM / IP Logged
The + video output is in position 5 of the DVD's plug. Negative video signal is in position 13 and the shield is in position 14.
sparky
Legrones
Copper - Posts: 75
Posted: February 16, 2004 at 7:50 PM / IP Logged
hi asapaudiopro did u get any info on the gm combo if so i am looking for the same info so i can hook one up if so send to legrones@sbcglobal.net
Dale / Cory
2004
Member - Posts: 16
Posted: March 06, 2004 at 7:59 PM / IP Logged
How's it going asapaudiopro,
 -------------> Sparky wrote,  "The + video output is in position 5 of the DVD's plug. Negative video signal is in position 13 and the shield is in position 14."
Did this work or did you have to do something else?
I am looking to add screens to mine, but wanted to get more info before I go and take the unit apart.
I have a 2004 Escalade, do you know if the factory dvd player in your 2004 suburban is the same model? Do you know what the model number is?
I assume from your post that the Dvd player does not have rca outputs on back. I haven't taken mine apart, so I am not sure.
Thanks, I can use all the help I can get
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
