Kenwood NAV System 2004 Tahoe
pvarela
Posted: March 01, 2004 at 6:39 PM / IP Logged
Just installed a Kenwood KNA-DV3100 Navigation system with the LZ-800W touchscreen on my 2004 Chevy Tahoe.  Thought I could do a better job than the dealer, but found very little in the area of schematics for the vehicle.  I thought I'd pass on the wiring that worked for that installation.  In this installation, the parking brake safety feature was bypassed by connecting the wire to an accessory with constant 12v+ power and adding a ground.  In the Tahoe, the illumination was tricky, because by using the normal (white) wire in the headlight control, the screen did not change, so we found an alternate, as noted below, that had a 5-volt change when the auto headlights came on - worked great!  Another thing to note is that there are 1 GREEN / WHITE wires behind the instrument panel - use the one in the A4 cavity of the connector for the VSS signal.  Also, measuring voltage from the reverse light - don't be alarmed if it measures higher than 12v - we got 14v from ours, both at the lamp end and at the kick panel.
KNA-DV3100 Wire                                2004 Tahoe Wire Color       Location in Tahoe
PRK SW (green) (parking brake)               Black wire                       cigarrette lighter
S SENS (white) (speed signal sensor)    GREEN / WHITE                    behind instrument panel in cavity A4
REVERSE (pink) (reverse lamp)                Light Green                     lower driver side kick panel in cavity J5
TEL MUTE (brown)                                        Not used
ILLUMI (orange)                                             BROWN / White                    light control panel driver's side
Ignition (red)                                                   Pink (12v+switched)       lower driver side kick panel in ignition harness
Batter (yellow)                                                Orange (12v+ constant)  cigarrette lighter
Ground (wire)        to car chassis
After trying with various manuals that listed different wire colors with no luck, and two days of having a NAV system that didn't navigate! -  these hookups finally worked. We recommend using a voltage meter if you are unsure of any wire colors or if your setup doesn't match what we have listed here.
Hope this helps anyone else doing a similar install.
Pat
pvarela
Posted: March 01, 2004 at 7:02 PM / IP Logged
UPDATE!!!!!
On the emergency brake bypass - I mentioned that we connected to a 12v constant - sorry - it is actually a ground wire from the cigarette lighter - sorry about mixup.
Pat
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
