Honda Pilot Video Install
Camz
Posted: March 14, 2004 at 12:18 AM / IP Logged
Need some info on installing a flip-down monitor in a Honda Pilot. There is no domelight access and I have heard there is only one spot to mount unit. Please advise. Thank you.
sparkie
Platinum - Posts: 2,061
Posted: March 16, 2004 at 2:14 PM / IP Logged
I believe there should be a roof beam located between the two "B" pillars (the posts behind each front door). If you cut a small hole in the center of the general mounting location you can peek above the headliner to locate the roof beam. Secure some wood to it and then mount your overhead screen to the wood.
sparky
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
