4GA or 8GA
jhoward75
Posted: June 12, 2004 at 10:32 AM / IP Logged
I am running one wire from the battery back to a distribution block then running a video switcher, 400W inverter, two LCD Monitors and  a DVD player. Should I use 4GA or 8GA wire to do this? I will not be adding anything else to this set up in the future. Thank you for your help.
Jeff Howard
jfk51502003
Copper - Posts: 221
Posted: June 12, 2004 at 1:27 PM / IP Logged
the generic rule is anything over 300 watts move up to 4 awg...although there is a formula...pretty sure on this site... possibly 4awg to block then split to 8 awg...again double-check...
12v_rep
Copper - Posts: 188
Posted: June 13, 2004 at 12:46 PM / IP Logged
You can never have too big of a wire, only too small.
jhoward75
Posted: June 13, 2004 at 12:56 PM / IP Logged
That's what I thought but I wasn't sure. Thanks for the help. Hope the kids will be watching DVD's and playing playstation by the end of the day.
Jeff Howard
jfk51502003
Copper - Posts: 221
Posted: June 16, 2004 at 12:02 PM / IP Logged
sure can never have to big of wire...but why have 0 awg and pay a thousand dollars or just get an 8 awg kit for exactly what you need for 30.00 bux.............?or whatever size you need there is a formula...check it find out wire size is compatible w/ your system...and purchase that size wire...if your gonna up-grade your system take that into consideration when  you buy...
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
