10.4 IN Monitor in 2002 Explorer
pappascw
Member - Posts: 13
Posted: December 23, 2004 at 8:19 PM / IP Logged
Anyone installed a 10.4 in Monitor in a 2002 Explorer with a Sunroof, no AC controls?
securinu
Silver - Posts: 772
Posted: December 26, 2004 at 8:47 PM / IP Logged
Yup we do the Myron & Davis all in one combo units. nice since the dvd is hard to put somewhere else.
Joe O'Byrne
Owner / Installer
pappascw
Member - Posts: 13
Posted: December 27, 2004 at 4:17 AM / IP Logged
What did you use to hang that puppy from the headliner?  Since there is a sunroof there is no support up there at all.  I may be able to catch the front bar but not sure what I can do to get support on the rear bolts..??
pappascw
Member - Posts: 13
Posted: February 17, 2005 at 5:27 AM / IP Logged
Anyone??
misterjimbo
Silver - Posts: 535
Posted: February 17, 2005 at 11:37 AM / IP Logged
i use a thin piece of wood. you get a little bit of bounce because of the headliner, but hey it has a sunroof. if you tell the customer ahead of time, iam sure they will understand. jsut make sure that the screws dont protrude throught the wood. to stabalize the wood i mount it to the thin metal bracket that is by the sunroof.  the sunshade passes over it. and it has  a few ridges in it. i screw throught the wood and get the screws into the low spot on the bracket so the shade doesnt snag on it.
pappascw
Member - Posts: 13
Posted: February 17, 2005 at 5:01 PM / IP Logged
I guess basically you get a small screw so you just make it thru the metal so it doesnt stick out. to hit the sunroof or shade...
