Multiple Monitors
Matrix7333
Copper - Posts: 54
Posted: April 03, 2005 at 12:30 PM / IP Logged
Hello all, I need some advice on how to power all these monitors.
 Two 6.4inch Headrest - Under 7w power consumption each.  I already have these installed. but one seems to flicker and the top left corner of the screen gets wavy like not enough power.
two(2) - 8 inch Visor monitors 9.5 w power consumption
One(1) 5 Inch Rearview with backup camara - This will automatically flip to the backup camara when i put the car   in Reverse. 9.5w power consumption
One Indash 7 inch Flip out one din Player - that will also replace my existing cd player so am not really worried about power here.
I currently have one main wire from the battery and have my remote start /alarm and tons of relays attach to it so nothing runs untill the car starts.  I also have a power inverter hooked up.  For the monitors, i currently have a power wire from that same main line comming from the battery with a relay that supply power to the monitors and dvd player when the car starts, otherwise there is no power.
Is it better to get a distribution block for this setup or can all these screens be powered from a really big gauge wire on a relay of course.  Do i need to have a relay for each monitor or is it okay to run them from one wire with one relay to control the power?
I also have a 6 output video amp installed and intend to be able to watch a different program on the visors than whats playing on the headrest monitors.
Any and all imput or suggestion for this setup would be much appreciated, thanks.
Matrix7333
Copper - Posts: 54
Posted: April 05, 2005 at 9:38 PM / IP Logged
Come on, there must be some smart fella here to help me??? Thanks
NowYaKnow
Gold - Posts: 1,217
Posted: April 05, 2005 at 9:46 PM / IP Logged
Just run a wire to the ignition/accessory wire at the steering column and throw a 15 - 20 amp fuse on it. You are drawing VERY little power no need to get crazy with thick wire, a distribution block, relays, or running power to the battery.
Mike
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
