How to cramp Video wire
arodriguez7015
Posted: May 13, 2005 at 6:31 PM / IP Logged
I accidentally cut off the Video cable from the 8 Pin. I split it open and there are wires and a yellow wraped wire inside of that what do I do in order to get an image?
Grove Side 214
auex
Platinum - Posts: 5,041
Posted: May 13, 2005 at 6:39 PM / IP Logged
Buy a new one of whatever it is that you have? You would need to reconnect the like colors back together. If you are trying to modify something then it would be better to post what it is you are actually trying to do to what.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
