Pioneer AVH-P5700DVD bypass
Jay22
Copper - Posts: 73
Posted: August 09, 2005 at 12:02 PM / IP Logged
Ok im going to be installing Pioneer AVH-P5700DVD in my car and all my music is gonna be VCD......I would like the video to play while the car is in drive....also for passengers (so dont flame me for doing it)..
I was told to put a three prong switch on the parking brake wire off the unit....can someone tell me how to wire it up??
thanks Jay
Jay22
Copper - Posts: 73
Posted: August 09, 2005 at 11:54 PM / IP Logged
anyone??
12v_rep
Copper - Posts: 188
Posted: August 10, 2005 at 7:29 AM / IP Logged
Have you tried doing a search on this topic? It has been covered in this forum about a dozen different times, so I am sure you will find your answer if you search a little. Good luck!!!
Platinum - Posts: 12,488
Posted: August 10, 2005 at 11:00 AM / IP Logged
Ground the GREEN wire on this unit.
Slammed_Am
Copper - Posts: 117
Posted: August 10, 2005 at 12:04 PM / IP Logged
My friend has the 5700 in his Caddy eldo, and its not as easy as just grounding the brake wire. Basically it needed to see ground, then taken away and ground again in order for his video to work. Just installed a toggle switch on the grounded green brake wire and that was that.
12v_rep
Copper - Posts: 188
Posted: August 10, 2005 at 12:31 PM / IP Logged
I do know that just grounding the wire does not work.
