2006 mustang stereo wiring
mark dog
Posted: October 28, 2006 at 3:26 PM / IP Logged
hi, i need a radio wiring diagram for my 2006 mustang with sub.  iam installing a nav. radio out of a 07 expedition, it fits right in but my sub does not come on,iam also getting a speed sensor error on the nav unit.   thanks for any help i can get.     Mark M
master5
Silver - Posts: 1,123
Posted: October 29, 2006 at 12:13 AM / IP Logged
You need to let us know which factory system the stang has.  I have all the info at work for each system so if no one else posts I will get it to you tomorrow.
As far as the speed sensor error did you connect the VSS wire? and if so, make sure your connection is good and on the right wire. If not let me know and I will post the VSS wire along with the sound system diagram.
However, I will probably not be able to get the pinouts for the 07 expo nav unit, perhaps someone else has access to that info.
take care
mark dog
Posted: October 29, 2006 at 11:07 AM / IP Logged
it is the shaker 1000 with the sub.  thanks again.
