2002 4Runner VSS & Reverse Wire
kingtim
Posted: December 22, 2006 at 3:09 PM / IP Logged
Hi,
Can someone post the VSS wire and the reverse wire for the 2002 4Runner? This is for the AVIC-D1.
Thanks!
KarTuneMan
Platinum - Posts: 7,056
Posted: December 23, 2006 at 8:21 AM / IP Logged
HEADLIGHTS Red At light switch harness   -
 REVERSE LIGHTS RED / white In driver's kickpanel   +
 DIMMER WHITE/ green At dimmer switch harness
 VSS WIRE GREEN/ orange At ECM behind glove box
 The GREEN/ ORANGE vss wire is located at the ECM behind the glovebox. On the 2.7L, pin-8 of the 22-pin connector. On the 3.4L, pin-22 of the 28-pin connector.
