2001 ford escape vss location
ramirez03
Member - Posts: 7
Posted: April 15, 2007 at 9:07 PM / IP Logged
hello i have a AVIC-N2 and want to know were is the location of the VSS wire for the 2001 Ford Escape v6 i know that it is gray/black wire but dont know were is the location
Val
Bnluis
Silver - Posts: 578
Posted: April 16, 2007 at 9:30 AM / IP Logged
"If you have cruise control, this is very easy to find.
Grey and Black wire going into the cruise control module on the passanger side engine compartment. It is right on top toward the back of the compartment with a black cable going to the throttle body of the enging."
" If you don't have cruise... it is a bit more difficult.
Grey and black wire going into the ABS module which is a bitch to get to. Located way down low under the brake booster. Can barely see it. Not sure where the wire harness is located on the unit. According to sources, it is also Grey and Black."
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
ramirez03
Member - Posts: 7
Posted: April 16, 2007 at 9:06 PM / IP Logged
hello i looked on the cruise control  but the cable dont have a gray and black cable going to it can you help me this is the only thing i need and i will be done with my installation on my 2001 ford escape.
Val
extreme1
Silver - Posts: 1,070
Posted: April 17, 2007 at 8:39 AM / IP Logged
ramirez, cruise control is on the passenger fender, it is a black box with a cable on one and and a connector on the the other, in the connector is the grey/black wire you're looking for.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Bnluis
Silver - Posts: 578
Posted: April 17, 2007 at 11:54 AM / IP Logged
2001 ford escape vss location -- posted image.
That it under the hood
Luis
Sound Waves
ramirez03
Member - Posts: 7
Posted: April 17, 2007 at 8:19 PM / IP Logged
i found the gray/black wire
thank you
Val
