07 fiord e250 van
Brianas
Copper - Posts: 50
Posted: June 23, 2007 at 3:48 PM / IP Logged
anyone install a double din nav in one of these
the dash opening appears to be 4 X 7.5"
so it should fit right in, what have you used to trim out the radio?
can a kit for and explorer/ranger be worked to fit?
looking at putting a avic-d3 in
thanks
Josh
AirWaveGT
Member - Posts: 17
Posted: June 25, 2007 at 9:33 PM / IP Logged
it will fit but i think you have to cut some plastic out though. you may have some gaps on the side too w/o any kind of trim ring on it. i've done 07 and earlier escapes and used back straps to mount it in so that should work for the econoline too. i havent personally installed a double din in one but coworkers have.
Brianas
Copper - Posts: 50
Posted: July 16, 2007 at 7:46 PM / IP Logged
thanks for the info, be installing on sunday,
ive done the escapes , cut the plastic sub dash , but always had a
nice finished look, no gaps.
i think on this van , if there are still gaps once installed, might try and work a dbl din
kit for the ranger/explorer for trim. ill post results.
thanks
Josh
