1997 Toyota Land Cruiser, Viper 5706V Wiring
fosterelli
Posted: April 25, 2024 at 8:19 PM / IP Logged Link to Post Post Reply Quote fosterelli
Working on a 1997 Land Cruiser - Viper 5706V Alarm/Remote Start. RS3000 was removed (OEM Security System). I have located all driver footwell harnesses & ignition harness. I have the EWD, and mixed results from many online forums & posts (there were variances in what goes where). Voltage status tested on the ignition harness w/ key position: CONSTANT, ACC, ON, START
11-PIN Ignition Harness has the following colors:
Male Plug End ; Female Socket End:
1 B-W ; B-W : START
2 B-Y ; B-Y : ON
3 L-R ; L-R : ACC & ON
4 B-R ; B : CONSTANT
5 Br-R ; Empty
6 Br-W ; B-R : ON
7 L ; W-B
8 L ; G-B
9 G-W ; W-B
10 G-W ; R-B
11 Br ; W-R : CONSTANT
I need to determine what to connect / where to connect the Viper wires.
MAIN 6-PIN
1 R     12V (+) CONSTANT DONE
2 B     GROUND (-) DONE
3 Br    SIREN OUTPUT (+) DONE
4 W-Br PARKING LIGHT ISOLATION #87A N/C ONBOARD RELAY
5 W     PARKING LIGHT OUTPUT #30 COMMON ONBOARD RELAY
6 O     GWA (-) GROUND WHEN ARMED OUTPUT
DOOR LOCK 3-PIN FRONT TWO DOORS WORKING, NEED TO DETERMINE REARS
1 L      UNLOCK OUTPUT (-) CONNECTED TO DRIVER DOOR KICK PANEL L-Y
2 EMPTY NOT USED
3 G      LOCK OUTPUT (-) CONNECTED TO DRIVER DOOR KICK PANEL L-B
REMOTE START 10-PIN  NOT WORKING YET
1 EMPTY     NOT USED
2 R-B     FUSED 12V (+) ACCESSORY/STARTER INPUT
3 P-B     FLEX (+) RELAY INPUT #87A N/C* KEY SIDE OF FLEX RELAY (IF R'QD)
4 P-W     IGNITION (+) 2 / - #30 COMMON OF FLEX RELAY
5 R     FUSED 12V (+) IGNITION 1 INPUT CONNECTED TO IGNITION B-Y
6 G     STARTER (+) INPUT KEY SIDE OF FAILSAFE STARTER DISABLE CONNECTED TO IGNITION B-W
7 V     STARTER (+) OUTPUT CAR SIDE OF FAILSAFE STARTER DISABLE CONNECTED TO IGNITION B
8 O     (+) ACCESSORY OUTPUT DONE
9 R-W     FUSED (+) 12V INPUT IGNITION 2 - #87 N/O* FLEX RELAY INPUT
10 P     IGNITION (+) 1 INPUT/OUTPUT
AUX SHUTDOWN TRIGGER 24-PIN
1   P-W       IGNITION 2 (-) FLEX RELAY OUTPUT
2   L-W       2ND STATUS REAR DEFOGGER OUTPUT (-)
3   R-W       TRUNK RELEASE OUTPUT (-)
4   B-Y       DOME LIGHT OUTPUT (-)
5   Drk L STATUS OUTPUT (-)
6   W-B       AUX 3 OUTPUT (-)
7   W-V       AUX 1 OUTPUT (-)
8   O-B       AUX 4 OUTPUT (-)
9   Gr       HOOD PIN INPUT (-) N/C OR N/O CONNECTED TO HOOD PIN
10 L-W       TRUNK PIN INSTANT TRIGGER INPUT (-) N/C OR N/O
11 W-L       ACTIVATION INPUT
12 V-W* TACHOMETER INPUT
13 B-W** PARKING BRAKE (-) INPUT GROUNDED THIS WIRE
14 G-B       FACTORY ALARM DISARM OUTPUT (-)
15 G*       DOOR INPUT (-)
16 Br-B HORN HONK OUTPUT (-) NOT USING
17 P       IGNITION 1 OUTPUT (-)
18 V*       DOOR INPUT (+)
19 V-B       AUX 2 OUTPUT (-)
20 Br       BRAKE SHUTDOWN INPUT (+) CONNECTED TO BRAKE SWITCH ABOVE PEDAL
21 V-Y       STARTER OUTPUT (-)
22 Gr-B DIESEL WAIT TO START INPUT (-) NOT USED
23 O       ACCESSORY OUTPUT (-)
24 G-W       FACTORY ALARM ARM OUTPUT (-)
* REQUIRED FOR MANUAL TRANS
** CONNECT TO PARK (-) BRAKE SWITCH
fosterelli
Posted: May 02, 2024 at 9:34 PM / IP Logged Link to Post Post Reply Quote fosterelli
Bumping this to see if I can get some help!
johnny12v
Posted: May 11, 2024 at 7:49 PM / IP Logged Link to Post Post Reply Quote johnny12v
hope this helps, its all the info that was posted on it
1997 Toyota Land Cruiser, Viper 5706V Wiring -- posted image.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
