troubleshooting viper 5704v
plastilanche
Posted: February 01, 2014 at 2:43 PM / IP Logged
Hello Everyone, New to the site but over the years, I’ve gathered a vast amount of extremely valuable information as a non member and would like to thank each and everyone first and foremost for all the indirect solutions and technical help! Hopefully in the future, I’ll be able to do the same!
I recently installed a Viper 5704V with a Directed D-Ball (Firmware GM5,V3.05 flashed by remote start experts ) for a bypass on a 2002 Chevrolet Avalanche.
After the install, I followed sequence for the D-ball Harness connection, followed instructions for programming to vehicle, and Paired the 2-way remote.
All my connections are soldered & heat shrunk. (the main reason for doing the install myself) and the grounds are good.
The good….
Siren functions
Parking lights function
The bad…
Door locks work off the remote while driver’s door is open; will NOT work while doors are closed. Kinda Strange.
Remote start comes up with an error (7 flashes) I tried the auto trans. Method (ignition on then off, hold valet button until chirp 3x, release, push once and hold, hit lock on remote)
Still no start.
Performed soft reset on D-Ball (reset just the vehicle program, not the firmware reset) now having trouble programming D-Ball to the vehicle.
With everything connected, I started the vehicle with the key, and the message center on the dash comes up with the “security” message.
At this point, is there something I missed? Will I have to have the D-Ball programmed with the firmware again?
My connections are as follows.
Bench soldered Viper alarm to D-Ball using XPRESSKIT GM5 Installation Type 4, W2W
Main Harness 6 pin
H1/1    Red + 12v constant Input-----------------------------Red 12v @ Ign Harness
H1/2    Black - Ground-----------------------------Chassis Ground
H1/3    Brown + Siren output-----------------------------Red + from siren
H1/4    WHITE/ Brown Parking light isolation pin 87a of onboard relay ---Not Used
H1/5     White Parking Light Output -------------------------Brown (Blue plug BCM Pin B6
H1/6      Orange – 500mh ground when armed output----------------------------Not Used
Door Lock Three Pin Connector
1     Blue -500ma Unlock Output-----------------Blue - unlock imput on 10 pin D-Ball
2     Empty Not Used
3     Green – 500ma Lock Output-----------------Green -lock imput on 10 pin D-Ball
Remote Start, 10- Pin Heavy Ga. Connector
H3/1   Pink 1 Ignition 1 Input / Output----------------------Pink @ Ignition Harness
H3/2   RED / White + fused 30 amp input ------------RED / White @ Ignition Harness
H3/3   Orange + Accessory Output----------------------Orange @ Ignition Harness
H3/4    Violet + Starter Input Car Side of Starter---------------Yellow @ Ignition Harness
H3/5     Green + Starter input Key Side of Starter----------------------Not Used
H3/6    Red + fused 30A ignition input----------------------Red @ Ignition Harness
H3/7   Pink/White + Ignition 2 flex relay output--------------White @ Ignition Harness
H3/8 Pink/Black + flex relay input 87A key side if required---------------Not Used
H3/9   RED / Black + Fused 30A Accessory/Starter inpu----- RED / White@ Ignition Harness
H3/10   NC No Connection
The Following Wires Are Connections From The D-Ball To Vehicle And/Or Viper
     14 Pin Blue Harness
14 pin Purple / YELLOW J1850-------Pin 2 of ODBII Purple
14 Pin Red 12V---------------------- Red 12v @ Ign Harness
14 Pin Black Ground---------------------- Chassis Ground
     12-Pin Red Harness
BLACK/ White RAP off? Driver door sense trigger---------Tan BCM purple plug pin B4
GREEN/ Black Bulb Test--------------------------------Not Used
GREEN / WHITE – door Status output------Viper 24-pin 15/Green – door input
RED / Black – trunk status output------- Viper 24-pin 10/ Blue – Trunk Pin input (n/c or n/o)
Violate/white tach output-------- Viper 24-pin 12/Violate/white Tach imput
Violate/Green R.Code-----------\
 ---Yellow @ Ignition Key
Violate/Brown R.code-----------/
ORANGE / Black Handbreak Status-------Not Used
     10-Pin Black Harness
Blue/White – GWR Status Input------- Viper 24-pin 5/Dark Blue – 200mA Status output
Pink + Ignition Input--------------------- H3/1   Pink 1 Ignition 1 Input / Output
Violate + Starter Input---------- H3/4    Violet + Starter Input Car Side of Starter
RED / White – trunk release input-------Viper 24-pin 3/RED / White – 200mA trunk release output
Blue – unlock input-----------Three Pin Viper Blue -500ma Unlock Output
Green – Lock Input------- Three Pin Viper Green -500ma Lock Output
     In Addition To The Above
Viper 24 Pin 9/Grey – Hood Pin Not used for initial install
Viper 24 Pin 13/BLACK/ White – Neutral Safety/Parking Break input---Ground to Chassis
smokeman1
Platinum - Posts: 1,588
Posted: February 01, 2014 at 7:18 PM / IP Logged
If you disconnect the connectors from the DB-ALL, put a key in the ignition but DON'T turn the key. Try to remote start. What happens?
Did you do the TACH Learn?
KPierson
Platinum - Posts: 3,527
Posted: February 02, 2014 at 10:20 AM / IP Logged
do you have the "disable" toggle switch installed and set properly?
Kevin Pierson
freqsounds
Copper - Posts: 289
Posted: February 03, 2014 at 8:29 PM / IP Logged
I would double check the CAN wires. Sounds like it's not talking to the car correctly.
Violet/Green and Violet/Brown connected together and spliced into the Yellow wire at the ignition.
Purple / YELLOW to pin 2 of the OBD connector.
If you are using D2D, you only need the 4 wires from the DBALL connected.
No question is stupid or not worth asking. You were once a noob, right? :)
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
