04 silverado convert 5volt wire to 12volt
pvcsilverado
Member - Posts: 30
Posted: April 30, 2014 at 2:00 AM / IP Logged
I have a 04 chevy Silverado it use to have the feature when the audio system stayed on for 15 minutes after u turned it off or when u opened a door. I changed the head unit and it doesn't do that no more.I found the wire that used to do that feature but its a 5volt wire. Ineed to know whats the best way to convert that 5volt wire to a 12 volt so it would switch on my relay to retain that feature? thank you!
pvc
oldspark
Gold - Posts: 4,913
Posted: April 30, 2014 at 2:56 AM / IP Logged
A 5V relay.
sparkie
Platinum - Posts: 2,061
Posted: April 30, 2014 at 2:13 PM / IP Logged
The wire you are testing isn't what you think. The original radio was turned on through a data signal which has nothing to do with whatever wire you are testing. You should use a radio replacement module from either Metra, Scosche or PAC. It will do what you want and retain door chimes etc, which are required for a vehicle safety.
sparky
pvcsilverado
Member - Posts: 30
Posted: April 30, 2014 at 3:33 PM / IP Logged
Thank you sparky!!youre a life saver!Now where can i get one of those!?
pvc
auto enhancers
Copper - Posts: 203
Posted: April 30, 2014 at 4:29 PM / IP Logged
should be able to get one at any local car audio shop
oldspark
Gold - Posts: 4,913
Posted: April 30, 2014 at 5:48 PM / IP Logged
I'll second pvcsilverado with another Thank you sparky!! you're a life saver!.
OldFarts like me with vintage cars often forget about comms & CANs.
[ If a user says 5V, I'll often assume they do mean 5V (DC). ]
Platinum - Posts: 13,725
Posted: April 30, 2014 at 9:35 PM / IP Logged
A Metra LC-GMRC01 is available at any reputable stereo shop. Retails for 70 dollars.
This is only useable if you did not cut the factory plug out of the dash.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
