Hooking up car radio with only sub out
levithan9
Member - Posts: 20
Posted: February 26, 2015 at 10:17 AM / IP Logged Link to Post Post Reply Quote levithan9
I recently got a car that I want to install a JVC radio. Also plan on putting in a 5 channel amp, so I don't have to run more wires than I need to.
Problem is, The head unit only has 1 RCA out that says SUB OUT. Do I just need to get a Y-splitter for each RCA out ( their are 2 RCA jacks, one white, one red) and just plug them into the INPUT of the amp (a Powerbass ASA 1100.5) and wire accordingly, or it is more involved than that?
Thanks in advance for your help.
itsyuk
Silver - Posts: 505
Posted: February 26, 2015 at 12:30 PM / IP Logged Link to Post Post Reply Quote itsyuk
what is th jvc model number?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
levithan9
Member - Posts: 20
Posted: February 26, 2015 at 2:47 PM / IP Logged Link to Post Post Reply Quote levithan9
Jvc KD-R330
itsyuk
Silver - Posts: 505
Posted: February 26, 2015 at 4:23 PM / IP Logged Link to Post Post Reply Quote itsyuk
that preout can be full range or sub depending on your settings.
se page 11 in the manual and you will find this
yuk
itsyuk
Silver - Posts: 505
Posted: February 27, 2015 at 12:59 AM / IP Logged Link to Post Post Reply Quote itsyuk
the Powerbass ASA 1100.5 allows you to run that single patchcord into it and run the whole amp. it states clearly in the installation manual what you need to do.
understand that doing it that way will not let you be able to fade front to rear and change subwoofer levels from the drivers seat unless you duct tape the amp directly to your steering wheel. LOL
you will need to carfully balance the system to keep from crawling in the trunk and re-adjusting for each song/artist.
yuk
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
