2004 Infiniti G35x sedan install
iheartmyv35
Posted: September 06, 2015 at 2:38 AM / IP Logged Link to Post Post Reply Quote iheartmyv35
I just got a 04 G35x sedan that i want to put a aftermarket dexk in and would like to know with the wiring harness and dash kit id my upper display that has the outside temp and ac control display will still function? If not i want to add a amp and subs where would be the best place to tap into speaker level input for a line level output converter for the amp?
Platinum - Posts: 13,725
Posted: September 06, 2015 at 9:00 PM / IP Logged Link to Post Post Reply Quote i am an idiot
According to Metra they did not make the x until 06. The dash kit for those vehicles retail for around 300 dollars. They include the electronics in the kit to keep everything working. The wiring harness sells for only 15 dollars. I do not remember if it needs the 20 dollar antenna adapter or not. If you are interested in doing it I will get you a part number for the kit. Are you installing single or double din unit? What color is the trim piece around your radio and it's controls?
iheartmyv35
Posted: September 15, 2015 at 5:02 PM / IP Logged Link to Post Post Reply Quote iheartmyv35
Im doing the double din. Got everything hooked up with metra wiring harness and dash kit. AC controls are working but no power from harness. Checked fuse under hood and its good. Im lost now.
iheartmyv35
Posted: September 15, 2015 at 5:04 PM / IP Logged Link to Post Post Reply Quote iheartmyv35
Its definetly a X one look under the car and you see the awd title says 2004 infiniti g35x
Posted: September 15, 2015 at 9:34 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Where did you ground the new radio? Did the factory radio work? Have you used a volt meter to verify that there is power on both the red and yellow wires of the new deck?
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
