1999 Tahoe, Alpine SEC8063 door lock connects?
dingo1
Posted: December 01, 2015 at 6:49 PM / IP Logged Link to Post Post Reply Quote dingo1
OK,First post..
Been signed up for a long time..Now I need a lil help..
Ive got a 99 Chevy Tahoe,4Door.
Im installing an Alpine/8063 Security system.
Heres the wiring for the alarm,
1999 Tahoe, Alpine SEC8063 door lock connects? - Last Post -- posted image.
Heres what I have for the trucks wiring..
1999 Chevrolet Tahoe Car Alarm Wiring Color Codes
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): White (This wire must be connected as ignition #2 for remote starting.)
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A). If vehicle is a 2-Door, door locks are a (Type”C”) If vehicle is a 4-Door, door locks are a (Type “A”).
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A). If vehicle is a 2-Door, door locks are a (Type “C”) If vehicle is a 4-Door, door locks are a (Type “A”).
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire (-): White (Requires Relay)
Domelight Supervision Wire Location: At Under Dash Light
Trunk Release Positive Wire (+): Black or BLACK/ White (If the vehicle has a rear lift gate, it is a (+) positive and if it has rear cargo doors, it is a 5 wire system. Requires Relay.)
Trunk Release Positive Wire Location: Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Horn Negative Wire Location: At Steering Column Harness
Any advisement?
dingo1
Posted: December 02, 2015 at 9:21 AM / IP Logged Link to Post Post Reply Quote dingo1
No luck..
I was hoping to determine weather I can connect directly,or if I need to set up relays,and if I do need relays,what set up..
the tahoe is 4 door,with barn doors in the rear..the rear does not need
to be connected.
trav39562
Posted: September 21, 2016 at 12:50 AM / IP Logged Link to Post Post Reply Quote trav39562
dingo
I have a question for you.I know this is an old thread but when you hooked up the 6 pin connector/harness, the diagram shows 5 wires but there is a 6th one that's BROWN / green. Did you hook this wire to anything? Sorry I couldn't help you with your problem.
travis
Tuesday, June 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
