Starting from scratch, stereo wiring, 84 Landcruiser
4david
Posted: May 04, 2017 at 11:28 AM / IP Logged Link to Post Post Reply Quote 4david
Hey all,
First post here. Basically I bought an old truck. I want to put a stereo in and a small sub. The problem is the wires are all 30+ years old. They are hard and brittle and I don't want to use any of them.
I need to wire everything from scratch. I'm talking about every speaker wire all the power, pretty much everything involved. Can anyone steer me to the right resource to help me figure this out. Advice is appreciated.
Thx
Just tryin not to screw it up
4david
Posted: May 04, 2017 at 11:30 AM / IP Logged Link to Post Post Reply Quote 4david
Oh sorry forgot to mention it's a 1984 Toyota landcruiser
Platinum - Posts: 13,725
Posted: May 04, 2017 at 8:34 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If you are running all new wires, what kind of information do you need?
4david
Posted: May 04, 2017 at 9:18 PM / IP Logged Link to Post Post Reply Quote 4david
I should have added that I do not have much of a working knowledge about the way car audio is wired meaning I don't really know where to start.
4david
Posted: May 16, 2017 at 9:36 PM / IP Logged Link to Post Post Reply Quote 4david
Bump
4david
Posted: May 25, 2017 at 4:29 PM / IP Logged Link to Post Post Reply Quote 4david
Not one person here knows anything?? Is this like a dead forum that's just a repository of information??
Posted: May 26, 2017 at 8:36 AM / IP Logged Link to Post Post Reply Quote i am an idiot
You will have to run wires from the radio to every speaker in the vehicle. Connect the white pair of the radio to the front left speaker. Connect the grey pair of the radio to the front right speaker. Connect the green pair to the left rear speaker. Connect the purple pair to the right rear speaker. I have never seen brittle wire in a vehicle from this era. I would try to find constant power, switched power in the factory wires. Ground the radio to the framework behind the radio or directly to the chassis of the vehicle. My guess is that the speaker wires are all intact and do not need to be rerun.
As for the amplifier, connect the power terminal of the amplifier to the battery, with a fuse holder no more than 18 inches from the battery. Ground the amplifier directly to the chassis of the vehicle with the wire as short as possible.
taraioi
Posted: June 24, 2017 at 11:20 PM / IP Logged Link to Post Post Reply Quote taraioi
I'd like to help you but I have no idea of it.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
