Diagram needed for an 03 Ram 1500
Junior73
Member - Posts: 11
Posted: May 20, 2004 at 11:37 AM / IP Logged
Like the heading says, does anybody have the diagram for an 03 Dodge 1500?  I am looking at installing a remote start as well, and was wondering if it has a setup like Fords securilock or GM's pass lock.
Thanks.
Keith
raydawg357
Silver - Posts: 769
Posted: May 20, 2004 at 1:06 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2003 / Remote Start
[PRINT THIS PAGE]
12voltspnk/blk & RED / wht + ignition harness
Starteryellow + ignition harness
Second StarterN/A
Ignitionblue (16 awg) + ignition harness
Second Ignitionred or RED / wht + ignition harness
Third IgnitionN/A
Accessorygreen & orange + ignition harness
Second Accessoryblue & blk/wht + ignition harness
Notes: These wires may not be necessary for remote start.
Keysenselt. blue - ignition harness
Power LockWHITE/ green - driver kick panel
Notes: Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays.
Power Unlocksame wire as power lock
Lock Motortan/pnk or tan/blk  driver kick panel
Unlock Motorblue  driver kick panel
Parking Lights+BLACK / YELLOW + relay under hood at pwr ctr
Parking Lights-purple / YELLOW - headlight switch
Notes: Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse LightPURPLE / black + automatic day/night mirror
Door Trigger  -
Notes: The LF door trigger is tan, and the LR door is tan/orange or PURPLE / orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan / YELLOW. These wires are in the passenger kick panel. Use all wires and diode isolate each. See DirectFax document 1076 for wiring information.
Dome Supervisionuse door trigger
Trunk/Hatch PinN/A
Hood Pin
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armlt. GREEN/ orange - driver kick panel
Notes: This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Factory Alarm Disarmsame wire as alarm arm
Disarm No Unlocksee factory alarm disarm
TachometerNOT GREEN/ orange ac ign coi, coil pack, or injector
Notes: Diesel tach wire use gray/black in the black plug at the PCM.
Wait to startsee DirectFax document 1091
Brake WireWHITE/ tan + brake pedal switch
Parking BrakeWHITE/ lt. green - parking brake switch
Horn TriggerBLACK/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C or 555U
Notes: Only vehicles with gray keys have the immobilizer.
Do it right the first time
Junior73
Member - Posts: 11
Posted: May 20, 2004 at 2:36 PM / IP Logged
Thanks for the quick reply!!!  The info is greatly appriciated!
Keith
