l.e.d. install
12v nut
Member - Posts: 20
Posted: September 12, 2004 at 2:38 AM / IP Logged
Hi,
for my first post i would like to wire a red led to a mom/off/mom switch which is negative.
The switch is linked to aftermarket central locking, i would like it to illuminate when locked, then go off when it
recieves the next - pulse unlock.
Any ideas.
draasch
Gold - Posts: 2,172
Posted: September 12, 2004 at 7:02 AM / IP Logged
is this just to show you when the doors are locked??
if so you can use a 12 volt LED....you will need some relays.....i will see if i have a diagram...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
12v nut
Member - Posts: 20
Posted: September 12, 2004 at 10:42 AM / IP Logged
Thanks,
to show red when locked,  i have a 12v led and some relays at the ready.
It is for a vans  rear cargo doors.
RufNUSD
Copper - Posts: 184
Posted: September 12, 2004 at 8:43 PM / IP Logged
Uh, just use the latched relay setup in the diagram section of this forum. You will kill your battery pretty quick due to the energized batteries in combination with your amperage pull of the LED. Cheers.
Someone pass me that bottle.
12v nut
Member - Posts: 20
Posted: September 14, 2004 at 3:43 PM / IP Logged
The led is to remain on only when the van is on the move,surely this wont kill the battery?
The led only shows when the cargo doors are locked by a switch on the dash,the alarm takes over to lock automaticaly
when the vehicle is not used.Cheers
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
