Pursuit PRO 9232 into F-150
haywireauto
Member - Posts: 18
Posted: April 25, 2005 at 10:56 PM / IP Logged
Hello, all,
I have recently acquired a Audiovox Pursuit PRO 9232a Keyless Entry Alarm Upgrade kit which I will be installing on my 2001 Ford F-150 Lightning. I have all of the installation instructions, plus a wiring color/location chart for the truck.
However, there seem to be several installation options (for instance, how to wire the door locks) that vary based on what type of vehicle the unit will be installed on. Is there anyone out there who perhaps has installed this particular unit into a 2001 F-150 who might be able to provide me with specific wiring information for this particular vehicle...?
All assistance is greatly appreciated. Thanks in advance.
Cheers!
Ken in SSF CA
KarTuneMan
Platinum - Posts: 7,056
Posted: April 26, 2005 at 12:45 AM / IP Logged
If the truck has factory keyless....locks are NEG(-) pulse...If NO factory keyless, they are reverse polarity.   The wires are found at the keyless module/ alarm.Im gonna think the truck came with keyless. Unlock is pink/green, disarm is GREEN/ purple...and to lock and arm, use the red, and the yellow. They are the wires for the 7/8 9/0 keyless buttons on the door. Trigger them at the same time, and diode isolate....
haywireauto
Member - Posts: 18
Posted: April 26, 2005 at 9:03 AM / IP Logged
KarTuneMan: Thanks for the response. Not sure about your reference to "keyless". The vehicle does NOT have the keypad on the driver's door. However, I do have the remote keyfobs to lock/unlock the doors without a key.
Thanks again.
Cheers!
Ken in SSF CA
daniel2002p
Silver - Posts: 524
Posted: April 26, 2005 at 10:17 AM / IP Logged
then you have neg- door locks.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
thepencil
Gold - Posts: 1,526
Posted: April 26, 2005 at 10:19 AM / IP Logged
Further note,
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2001 / Keyless Entry
12volts yellow and lt. GREEN/ purple   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Ignition dk. blue/lt. green   +   ignition harness
Power Lock pink / YELLOW      passenger kick, door harness
Notes: Negative pulse, type B, on keyless entry models. Five wire, type C, on non-keyless models, mastered from the driver switch.
Power Unlock pink/green      passenger kick, door harness
Notes: The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake-up the system refer to directfax document #1093.
Lock Motor pink/black   5wi driver kick, door harness
Unlock Motor RED / orange   5wi driver kick, door harness
Parking Lights+ brown   +   headlight switch
Notes: May also be found at trailer connector next to diagnostic connector under dash.
Parking Lights- lt. GREEN/ YELLOW   -   headlight switch
Notes: If equipped with autolamps.
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger BLACK/ yel (L), BLACK/ pink (R)   -   see notes
Notes: The BLACK / YELLOW catches the drivers door and the BLACK/ pink catches the passengers door. The wires are found in their respective door harnesses. On the Super Crew the rear door trigger is BLACK/ lt. blue low in the driver kick panel. Use all wires and diode isolate each. See DirectFax document 1076 for wiring information. Both wires may also be found at the GEM module located above the fuse box. On models without a dome light delay use ORANGE / lt. green (-) at the light switch.
Dome Supervision BLACK/ lt. blue   +   passenger kick panel
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Notes: Arms when locked with the door open. To simulate, send a negative trigger to the lt. blue/white wire at the RAP module, located behind the light switch, while locking.
Factory Alarm Disarm dk. GREEN/ purple   -   driver kick, door harness
Disarm No Unlock
Horn Trigger dk. blue   -   horn switch
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: PATS Part #: 555P, 555F, 556U, or 555U
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2001 / Keyless Entry
12volts yellow & lt. GREEN/ purple   +   ignition harness
Ignition RED / black (larger of 2)   +   ignition harness
Notes: Non-keyless versions are 5 wire located in the driver door harness. Keyless versions are negative trigger located in a gray molex plug to the right side of the steering column.
Power Unlock pink/lt. green
Unlock Motor pink/black or RED / orange   5wi driver kick, door harness
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger BLACK/ lt. blue   +   gray plug right of column
Dome Supervision use door trigger
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Horn Trigger dk. blue   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.Pursuit PRO 9232 into F-150 - Last Post -- posted image.
KarTuneMan
Posted: April 26, 2005 at 11:20 AM / IP Logged
They gave you all the CORRECT answers.....get to work.....Pursuit PRO 9232 into F-150 - Last Post -- posted image.
haywireauto
Member - Posts: 18
Posted: May 09, 2005 at 10:56 AM / IP Logged
Thanks to all for the information!!
Cheers!
Ken in SSF CA
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
