99 honda accord ex alarm/remote start
BaggedTruck
Member - Posts: 16
Posted: August 05, 2005 at 1:43 AM / IP Logged
i have a 99 accord ex sedan that Im going to put an autopage rs720 in...i was looking through the car and looking for the wires that are on the wiring diagram here but some dont seem to match, or im not looking in the right spot...but i was wondering if anyone knew of anoither wiring schematic i could use or where to get one????
Don't hop it...Bodydrop it
mo12v
Posted: August 05, 2005 at 8:14 AM / IP Logged
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK / YELLOWIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH AHRNESS *
Dome LightBLACK/ WHITE (-)4 PIN CONN. IN PASSENGER FUSE BLOCK
Trunk Pin SwitchORANGE (-)18 PIN CONN. IN DRIVER KICK PANEL
Parking LampRED / BLACK (+)GREEN 20 PIN CONN. DRIVER FUSE BLOCK
Power LockBLACK/ WHITE2 PIN GRAY CONNECTOR IN
Power UnlockGREEN/ REDDRIVER KICK PANEL (LX MODEL) **
* Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block. **EX Model Access Door Locks At Passengers Side Multiplex 20 Pin GREEN Con Unlock BLU/ORN (-) Pin 4 Lock BLACK/ ORANGE(-)Pin 16.Behind Lower Cover.
Negative Pulse Door Locks
Accessories
Window UpD\ RED / YEL P\ BLU/WHT RED / BLU P\ RED / BLU @ EACH SWITCH*
Window DownF/ RED / BLU F/ BLU/YEL R/ RED / YEL R/ RED / YEL *
Ign Key WarnBLUE/WHITE (-)IGNITION SWITCH HARNESS
Trunk ReleaseGRN/BLU (-) AT KEYLESSMODULE (LX), WHT/RED (+)(EX)****
OEM HornLIGHT GREEN/ BLUE (-)STEERING COLUMN HARNESS **
HeadlightsBLUE/RED (-)HEADLIGHT SWITCH
OEM Alarm ArmSEE TECH ON IGNITION DISABLE
OEM Alarm DisarmORANGE (-)BEHIND GLOVE BOX IN 24 PIN CONNECTOR
* Due To Multiplexing Window Wires Must Be Accessed At Each Window Switch But All Are Reverse Rest At Ground Type Circuits. ** Horn Wire Can Also Be Found At GREEN 16pin Connector AT Passenger Fuse Box. *** Disarm Can Be Found As BLUE (-) At Driver Multiplex Unit (Door Switch). **** Located At Pass Multiplex Control Unit Behind Right Side Glove Box.
Reversal Rest At Ground Window Circuit
Remote Start
Tach SignalBLUEWHT 2 PIN TEST CONN-PASS REAR ENGINE*
Ignition #2YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryWHITE/ BLACKIGNITION SWITCH HARNESS
Neutral SafetyBLUE/WHITE (-)GREEN 20 PIN CONN DRIVER FUSE BLOCK
Brake LightWHITE/ BLACK (+)SWITCH ABOVE BRAKE PEDAL
Reverse LightGREEN/ BLACK (+)GREEN 10 PIN CONN DRIVER FUSE BLOCK
Rear Window DefrostBROWN / YELLOW (-)REAR DEFOGGER SWITCH
Immobilizer Bypass
. * 4 Cylinder Models- 6 Cylinder Models Connector Is On Driver Rear Of Engine
EX Model- RKE Built Into Passenger Multiplex Unit
MO
thepencil
Gold - Posts: 1,526
Posted: August 05, 2005 at 9:10 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / ACCORD / 1999 / Remote Start
12volts white   +   ignition harness
Starter BLACK/ white   +   ignition harness
Notes: If doing starter kill, must interrupt the wire between the keyswitch and the fusebox, not between the fusebox and the starter, to keep the check engine light from coming on.
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow   +   ignition harness
Second Accessory WHITE/ black   +   ignition harness
Keysense
Power Lock BLACK/ blue   -   passenger side fuse box
Notes: in a green 20 pin connector.
Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box.
Power Unlock orange   -   passenger side fuse box
Lock Motor WHITE/ red      driver side fuse box
Unlock Motor        driver side fuse box
Notes: yellow on the EX and lt. GREEN/ red on the LX
Parking Lights+ RED / black      driver side fuse box
Parking Lights- RED / yellow      steering column
Notes: Only available on the EX model.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light GREEN/ black   +   driver side fuse box
Door Trigger BLACK/ white   -   passenger side fuse box
Notes: In a green 4 pin connector.
Dome Supervision use door trigger
Trunk/Hatch Pin orange   -   drivers kick panel
Notes: Above the hood release in a gray 18 pin connector. On the DX & LX models, also found in a 2 pin connector behind the drivers fuse box.
Hood Pin yellow/red or yellow   -   hood pin switch or
Notes: On the EX models it is in a green plug next to the passenger side fuse box. On the LX models it is at the keyless/security unit, if equipped, which is attached to the driver side underdash panel.
Trunk/Hatch Release WHITE/ red   +   drivers kick panel
Power Sliding Door
Factory Alarm Arm
Notes: Arms and disarms with the door locks on the EX models. The LX models arm only with the factory transmitter.
Factory Alarm Disarm
Disarm No Unlock blue   -
Notes: On the EX the wire is located at the drivers power window switch, on the LX the wire is at the keyless/security unit which is attached to the drivers underdash panel.
Tachometer blue      tach test connector
Notes: The tach test connector is located behind the battery on the 4 cylinder, and on a bracket attached to the drivers side strut tower on the 6 cylinder motor. The tach test connector is a white 2 pin connector, and may be covered by a black rubber boot.
Wait to start
Brake Wire WHITE/ black   +   brake pedal switch
Parking Brake
Horn Trigger lt. GREEN/ blue   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: 555H
Alternate Part3 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.99 honda accord ex alarm/remote start - Last Post -- posted image.
BaggedTruck
Member - Posts: 16
Posted: August 06, 2005 at 4:12 AM / IP Logged
thanks guys!
BaggedTruck
Member - Posts: 16
Posted: August 10, 2005 at 1:39 PM / IP Logged
I just finished putting in the autopage 720 and I wired up the 555H but it doesnt seem to work....The LED comes on to show that it owrks but when you program the key the LED is supposed to go off but doesnt. I have tried my 2nd key but still the same problem.  Has any one had this prob, or know of a way to fix???
Teamrf
Gold - Posts: 1,031
Posted: August 10, 2005 at 8:09 PM / IP Logged
The 555H is pretty easy. Is it lighting up telling you that it learned the code? What wires did you grab do you have all the power connections?
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
