How do i fit neons in the boot?
andr3w
Member - Posts: 6
Posted: January 23, 2006 at 6:28 AM / IP Logged
How do i fit neons in the boot of my ford mondeo MK2? BUT not drilling into the side of the car?, i've tryed double sidded stikkie tape but it gets hot and dont stick,
just give me random idears and ill try it out,
Andrew,
jlord16
Silver - Posts: 322
Posted: January 23, 2006 at 8:35 PM / IP Logged
Industrial strength Velcro would be worth a try, but it may have the same results as double sided tape due to the heat
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
auex
Platinum - Posts: 5,041
Posted: January 23, 2006 at 9:50 PM / IP Logged
Well not exactly knowing the vehicle, if your vehicle has a rear deck I would mount them with screws or zipties to the rear deck. If it is a hatch then you can cut two 1/4" slits into the liner/carpet and hang them with zipties or use screws and speed clips.
A picture of the trunk/hatch would give a better idea of what you are dealing with.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
rangeroveruk
Member - Posts: 7
Posted: January 23, 2006 at 11:41 PM / IP Logged
Where is the Heat comming from ?
where are you trying to mount the Neons
i've got a mondeo and find it hard to beleive your having that much trouble
juniorxs
Member - Posts: 26
Posted: January 24, 2006 at 4:58 AM / IP Logged
silicone sealent will do it, tape the neon in place while it dries though
andr3w
Member - Posts: 6
Posted: January 30, 2006 at 6:31 AM / IP Logged
auex, i cant take pictures of the car.. i aint got a pc camera,
rangeroveruk, the heat is comming from the corner of the neon where the wire is attached,
juniorxs, i've done it and its wicked, thanks,
all i've gotta do is add speekers to the roof... Any idears?
