Astrostart 1105 in a 2006 Hyundai Azera
edibear
Posted: July 14, 2006 at 1:45 PM / IP Logged
I am preparing to install an Astrostart 1105 remote start into a 2006 Hyundai Azera SE. I am looking for the Hyundai Azera wiring diagrams and if possible a copy of the Astrochart installation information from Astrostart.
josh1979
Silver - Posts: 320
Posted: July 15, 2006 at 8:50 PM / IP Logged
12volts pink (40A), red (30A)  +  ignition harness
Starter green  +  ignition harness
Second Starter N/A
Ignition blue  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory orange  +  ignition harness
Keysense GREEN/ black  -  ign harn or BCM, 16 pin plug, pin 8
Notes: The BCM (Body Control Module) is under the driver side dash, left of the brake pedal switch.
Power Lock BROWN / orange  -  DDM, 23 pin plug, pin 16
Notes: Meter this wire while turning the key in the driver door key cylinder.
The DDM (Driver Door Module) is the power window main switch in the driver door.
Power Unlock pink (double pulse)  -  DDM, 23 pin plug, pin 17
Lock Motor red  5wi dr kick or DDM, 16 pin plug, pin 9
Notes: The DDM (Driver Door Module) is the power window main switch in the driver door.
Unlock Motor orange  5wi DDM, 16 pin plug, pin 14
Parking Lights+ BROWN / org (L), gray/org (R)  +  back of fuse box, 20 pin plug
Parking Lights- yellow  -  BCM, 26 pin plug, pin 8
Also found in the front of the fuse box, 20 pin plug, pin 5.
Hazards WHITE/ orange  -  switch or BCM, 22 pin plug, pin 2
Turn Signal(L) pink  +  dr kick or BCM, 14 pin plug, pin 14
Turn Signal(R) orange  +  dr kick or BCM, 14 pin plug, pin 13
Reverse Light white  +  back of fuse box, 9 pin plug, pin 5
Door Trigger BLACK/ orange to black  -  dr kick or BCM, 22 pin plug, pin 1
Dome Supervision yellow/orange to yellow  -  BCM, 14 pin plug, pin 2
Also found in the back of the fuse box, 24 pin plug, pin 7 or the driver side A pillar.
Trunk/Hatch Pin green  -  dr kick or BCM, 22 pin plug, pin 12
Hood Pin gray/orange  -  pin sw or BCM, 16 pin plug, pin 6
Trunk/Hatch Release blue/orange  -  BCM, 26 pin plug, pin 21
Also found at the trunk release on/off switch in the glove box.
The trunk release motor wire is orange (+) in the back of the fuse box, 24 pin plug, pin 1.
The fuel lid release is green (+) in the driver kick, harness to the rear.
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ign, acc, and key sense
Tachometer white to green  ac  PCM, connector A, pin 61
Notes: The PCM (Powertrain Control Module) is next to the driver side strut tower. Connector A is the plug towards the center of the vehicle.
Also found in the driver kick, 33 pin plug, pin 3 or the instrument cluster, 16 pin plug, pin 9.
Can also go to any fuel injector and use the wire that is NOT orange.
Can also go to any ignition coil and use the wire that is NOT pink.
Wait to start N/A
Brake Wire green to red  +  brake pedal switch or driver kick
Parking Brake pink  -  switch or BCM, 22 pin plug, pin 13
Horn Trigger white to yellow/orange  -  switch or BCM, 26 pin plug, pin 5
Memory Seat 1 WHITE/ orange  -  memory seat switch in door
Memory Seat 2 yellow/black  -  memory seat switch in door
Memory Seat 3 N/A  -
Astrostart 1105 in a 2006 Hyundai Azera - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays
bring back the rotary phone so i dont have to press 1 to proceed in english
Wednesday, June 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
