2000 Toyota Echo Alarm/Remote Start Wiring
Welcome Guest :)
t_26dragon
Member -
Posted: December 27, 2006 at 9:13 PM / IP Logged
Hello I would like to know if u have a wiring diagram for a 2000 Toyota Echo if so that would be great.
Thanks Travis
Email m_shelly22@yahoo.com
KarTuneMan
Platinum -
Posted: December 28, 2006 at 9:44 AM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
12 VOLTS | WHITE/ red or WHITE/ blue | Ignition switch harness | + |
IGNITION | BLACK/ red | Ignition switch harness | + |
IGNITION 2 | BLACK / YELLOW | Ignition switch harness | + |
ACCESSORY | Runs with ignition | | |
STARTER | Black (small gauge) | Ignition switch harness | + |
| | You may need to isolate the starter wire from the ignition switch when doing a remote starter to prevent it from feeding back and engaging the starter when the key is turned on. See the TIP diagram. |
KEY SENSE | Yellow | At ignition switch harness | - |
TACH SIGNAL | SEE NOTES | Top of engine | AC |
| | Remove plastic engine cover to expose 4 coils. Each coil has a 4-wire plug with 3 of the wire colors common to all 4 coils. Use the odd color at any of the coils for a 1-cylinder reference signal. |
FUEL INJECTOR | Opposite from BLACK/ red | At any injector on engine | AC |
LOCK | BROWN / yellow | On 14-pin plug in DKP | - |
UNLOCK | GREEN/ black & Blue/red | On 14-pin plug in DKP | - |
| | Equipped with Toyota's Child Safety Door-lock system. Both wires must be connected for doors to unlock properly. See the door-lock diagram for details. |
DOORPIN | RED / white or Blue / YELLOW | At Junction block in driver's side dash | - |
TRUNK PIN | RED / blue | At light in rear compartment | - |
FACTORY ARM | BLACK/ red | In harness from driver's door | - |
FACTORY DISARM | Blue / YELLOW | In harness from driver's door | - |
KarTuneMan
Platinum -
BRAKESWITCH | GREEN / WHITE | At switch above brake pedal | + |
PARKLIGHTS | GREEN/ sil. Dots | At fusepanel or DKP | + |
HAND BRAKE | Yellow/red | 14-pin plug below radio in dash | - |
HORN | WHITE/ red | Ignition switch harness | - |
CLUTCH SWITCH | WHITE/ black | At switch on clutch pedal | TYPE 2 |
DRIVER WINDOW UP | Red | At switch in driver's door | REV POL |
DRIVER WINDOW DOWN | Green | At switch in driver's door | REV POL |
PASSENGER WINDOW UP | Blue/red | In harness from driver's door | REV POL |
PASSENGER WINDOW DOWN | Blue / YELLOW | In harness from driver's door | REV POL |
LEFT REAR WINDOW UP | RED / yellow | In harness from driver's door | REV POL |
LEFT REAR WINDOW DOWN | GREEN/ YELLOW | In harness from driver's door | REV POL |
RIGHT REAR WINDOW UP | RED / black | In harness from driver's door | REV POL |
RIGHT REAR WINDOW DOWN | GREEN/ black | In harness from driver's door | REV POL |
HEADLIGHTS | RED / blue | At light switch harness | - |
REVERSE LIGHTS | RED / yellow or RED / black | At junction block in driver's dash | + |
DIMMER | WHITE/ black | At dimmer switch in dash | + |
VSS WIRE | Violet/white | Pin-9 of 22-pin plug on ECM | |
| | These wires can also be found at the Factory alarm module on the right side of the steering column near the firewall. |
Friday, June 7, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
