2008 Chevrolet Avalanche Alarm/Remote Start Wiring
Welcome Guest :)
stevetolentino
Member -
Posted: March 26, 2008 at 4:50 PM / IP Logged
Installing a alarm, need diagrams for a 08 Chevy Avalanch,
Thanks in Advance
KarTuneMan
Platinum -
Posted: March 26, 2008 at 7:17 PM / IP Logged
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| | This vehicle is equipped with a TRANSPONDER passive anti-theft system. A bypass module may be available which will not require a key. Contact your supplier to find out. If one is not available to you, please see the appropriate security diagram before any remote start installation. |
12 VOLTS | RED / black | In black plug on fusebox under dash | + |
IGNITION | Pink | Ignition switch harness | + |
ACCESSORY | Brown | Ignition switch harness | + |
STARTER | White | Ignition switch harness | + |
| | Start wire requires (+) through a 1280 ohm resistor. |
KEY SENSE | Pink | Ignition switch harness | + |
TACH SIGNAL | SEE NOTE | | |
| | Go to any coil on the side of the engine and use the wire that is not Pink, Black or Brown. |
FUEL INJECTOR | Opposite from Pink | At any injector on engine | AC |
LOCK | Data module required | | |
UNLOCK | Data module required | | |
DOORPIN | Gray | At BCM on the left side of the steering column | + |
| | Located in the TAN connector. |
FACTORY ARM | Data module required | | |
FACTORY DISARM | Data module required | | |
| | The OEM alarm will disarm automatically on remote start. |
BRAKESWITCH | Blue/white | At switch or BCM on left of steering column | + |
| | Located in the BROWN connector. |
PARKLIGHTS (-) | Lt.blue | At light switch or BCM on left of steering column | - |
HAND BRAKE | Lt.blue | At BCM on left of steering column | - |
HORN | Tan | At steering column or BCM | - |
| | Located in the BROWN connector. The BCM is located on the left side of the steering column. |
VSS WIRE | Yellow/black | In Black connector on ECM | AC |
| | The ECM is located on the driver's side of the engine compartment behind the headlight. |
stevetolentino
Member -
Posted: March 26, 2008 at 10:32 PM / IP Logged
Thank you very much, I appreciate it!
Wednesday, May 15, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
