radio stolen, reconnecting fac.
djmicdamn
Posted: January 08, 2009 at 5:00 PM / IP Logged
Ok so heres my long story short.
I had a Pioneer AVIC-Z2 stolen from my 07 Altima 2.5S last night. Thank God for Allstate since its covered. But anyways, I want to reinstall the Factory radio however they cut the antenna wire and all I have is the connector that goes to the antenna connection of the factory stereo and 2 bare wires. I did manage to climp them back to the connectors. Obviously the radio wont power on without those 2 wires, ground and antenna or something. The other harness(for power and audio for stereo) was untouched. So I plug everything back in and turn it on. The screen and everything is fine but all I hear is hiss from the speakers. No matter what source, all I hear is hiss. Even CD's and AUX.
Someone please help, I would really appreciate it.
hurtado_roberto
Copper - Posts: 196
Posted: January 08, 2009 at 5:27 PM / IP Logged
What are those two bare wires you mentioned?  What color are they?  Check the wiring codes on the following link to try to figure it out...
https://www.the12volt.com/installbay/forum_posts.asp~TID~87098
Poly Dollies
djmicdamn
Posted: January 08, 2009 at 5:41 PM / IP Logged
those two wires are the ones that belong in the factory antenna connection. they just cut em but i put em back together.
it looks like this, its just the gray piece with two black wires
radio stolen, reconnecting fac. - Last Post -- posted image.
hurtado_roberto
Copper - Posts: 196
Posted: January 08, 2009 at 5:50 PM / IP Logged
Maybe you have a factory amp in your car.  When I installed an aftermarket stereo in a suburban, I just bypassed the amp.  I bypassed it where the amp is at, not at the rear of the stock stereo.  You can try to connect a speaker to a speaker output like blue/white and blue/red to see if you're getting an output directly out of your stereo.
Poly Dollies
djmicdamn
Posted: January 08, 2009 at 5:55 PM / IP Logged
yeah i checked for that but i dont have an amp
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
