speaker setup
ca$ino
Copper - Posts: 67
Posted: March 18, 2009 at 10:04 PM / IP Logged
How should i connect my speakers?
I've got 2 SVC 10" 225RMS MTX's and already have them mounted in custom box, have head unit as well, and am getting a 600watt Kenwood amp tomorrow. I'm wondering which is the best way to set them up and why?
Parallel or Series? Why?
Can someone tell me when or where i'd run a series setup versus a parralel setup?
Thanks in advance!
Look twice, think thrice, 1 splice/ 1 slice!
This is a phrase i came up with and something i will now live by.
soundnsecurity
Gold - Posts: 2,711
Posted: March 18, 2009 at 10:19 PM / IP Logged
it depends on the specs of the amp which would be better to use. but if your subwoofers are single 4 ohm voice coils, you will want to do a series hook up which will give you a total ohm load of 2 ohms at the amp if it is a mono amp. if you are getting a 2 channel amp just hook up one sub to each channel, it is the same thing.
ca$ino
Copper - Posts: 67
Posted: March 18, 2009 at 10:31 PM / IP Logged
Also, would 8gauge wiring suffice for said setup?
soundnsecurity
Gold - Posts: 2,711
Posted: March 18, 2009 at 10:36 PM / IP Logged
8 gauge would be ok for one of said amps
ca$ino
Copper - Posts: 67
Posted: March 19, 2009 at 4:58 PM / IP Logged
1 more question i've been lookin at the parallel and series calc, as well as the sub wiring diagram, and am wondering.. on a 2channel amp, if i hook up a sub to each channel, this will indeed be a 2ohm load correct?
or is it still 4ohm since each sub is on it's channel?
j.reed
Copper - Posts: 716
Posted: March 19, 2009 at 10:22 PM / IP Logged
4 ohm on each channel.
speaker setup -- posted image.
ca$ino
Copper - Posts: 67
Posted: March 20, 2009 at 4:27 PM / IP Logged
Thanks J
boogeyman
Silver - Posts: 359
Posted: March 28, 2009 at 7:42 PM / IP Logged
  one sub per channel to that amp...........8 gauge power wire will be fine, but I always recommend 4 gauge power wire the reason being if decide to upgrade or add a second amp you dont have to purchase another amp kit,take the 8 gauge out and run the 4 gauge because its already done.....and the 4 gauge amp kit is only a few bucks more.
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
