subsonic filter
blackcivichatch
Copper - Posts: 229
Posted: November 03, 2009 at 8:59 PM / IP Logged
So my new amp (SPL DK2 2000) has a sub sonic filter. there isn't a switch to turn it on and off. and its lowest level is at 30Hz. is there any way I can disable the subsonic filter?
UNLABELED Custom Car Club President
forbidden
Platinum - Posts: 5,353
Posted: November 03, 2009 at 10:33 PM / IP Logged
What makes you want to disable it?
blackcivichatch
Copper - Posts: 229
Posted: November 03, 2009 at 10:52 PM / IP Logged
30Hz seems a lil high.. Feels like I'm loosing a little on the low side. It might jus be my imagination though.
Does it cut everything off lower than 30, or is it a roll off?
haemphyst
Platinum - Posts: 5,054
Posted: November 04, 2009 at 8:43 AM / IP Logged
Just like any crossover, it's a roll-off. 30Hz is the 3dB down point. Seems like a super-dee-duper amp that you can't even adjust to a decent frequency, let alone disable the subsonic... Where'd you get it so I don't make the same mistake...? Are you absolutely certain you can't disable it?
blackcivichatch
Copper - Posts: 229
Posted: November 04, 2009 at 8:39 PM / IP Logged
Well I got it from a friend of a friend. They go for about $300 new. It was only used for a couple months. Its only temporary till i can afford the pdx 1000.1. And Yes unfortunately it cannot be disabled.
blackcivichatch
Copper - Posts: 229
Posted: November 04, 2009 at 8:44 PM / IP Logged
subsonic filter -- posted image.
Platinum - Posts: 13,693
Posted: November 05, 2009 at 2:00 AM / IP Logged
If I happen to have one of those jewels come across my bench in the next few weeks, I will open it up and see if I can figure out for you.  Depending on how the filter is designed, it may be as simple as changing a couple resistors to lower the frequency to 15Hz.
blackcivichatch
Copper - Posts: 229
Posted: November 05, 2009 at 7:21 AM / IP Logged
That would be amazing and greatly appreciated. If i got ahold of a high def camera, do you think pictures of the circuit in that area would help?
DYohn
Moderator - Posts: 10,741
Posted: November 05, 2009 at 10:26 AM / IP Logged
SPL is Power Acoustik's bargain brand, if that tells you anything... If you can't turn off the subsonic high pass, then you probably do not want to use this amp with a sealed subwoofer system.  Indeed, I would recommend not using this amp period, but that's just me...
blackcivichatch
Copper - Posts: 229
Posted: November 05, 2009 at 11:15 AM / IP Logged
Lol. I'm beginning to agree. I'm gonna see if i can get someone else to buy it off me and try my luck again. I really just need something cheap for temporary. Plus the SPL logo lights up bright blue and I'm goin for green... So I guess its back to Ebay. subsonic filter -- posted image.
