noob ’87 crown victoria, head unit
mitymerc
Posted: November 06, 2009 at 9:27 PM / IP Logged
I'm attempting to install a new clarion head unit in my '87 Crown Vic Country Squire. I am replacing the factory digital cassette w/external amp & 6 speakers.
I have a 4 channel floating ground adapter connected as per the schematic/color codes.
I get the hu display, but no sound output.
I scanned the schematics, but they are pdf's & I can't post them.
I did find this.....
https://www.the12volt.com/installbay/forum_posts.asp?tid=56694&KW=crown+vic
I didn't connect the bl/wh wire as I thought that was for an aftermarket amp, could this be the solution?
I don't want to start indescriminately connecting things and make smoke LOL
Thanks in advance
mitymerc
Posted: November 07, 2009 at 5:16 PM / IP Logged
Anybody?
scrtcell
Member - Posts: 22
Posted: November 07, 2009 at 6:30 PM / IP Logged
if i am not mistaken that year car already is set up for floating you need to recheck your wiring,you can use a testlight in that car to check for power and then use a 9 volt battery to check for your speakers
Platinum - Posts: 13,672
Posted: November 07, 2009 at 7:06 PM / IP Logged
1986-89 Ford Crown Victoria Stereo Wiring
Constant 12V+GREEN/ YELLOW
Switched 12V+Yellow/Black
GroundChassis
IlluminationBlue/Red
Dimmern/a
Antenna TriggerORANGE / Blue
AntennaRight Front
Front Speakers5" Dash
Left Front (+)ORANGE / Green
Left Front (-)BLACK/ White
Right Front (+)WHITE/ Green
Right Front (-)BLACK/ White
Rear Speakers6" x 9" Rear Deck
Left Rear (+)Pink/Green
Left Rear (-)Pink/Blue
Right Rear (+)Pink/Blue
Right Rear (-)GREEN/ Orange
mitymerc
Posted: November 07, 2009 at 10:37 PM / IP Logged
The stock amp appears to be floating however, the adapter harness from the HU has both + and - wires.....
Use a 9V batt?
mitymerc
Posted: November 07, 2009 at 10:39 PM / IP Logged
i am an idiot wrote:
Thank you, I downloaded this already, It appears to be for the 4 speaker sedan, I have a wagon w/premium sound (6 speakers & external amp)
