2010 Ford Sporttrak Alarm/Remote Start Wiring
Welcome Guest :)
taylermade
Member -
Posted: October 28, 2010 at 2:49 PM / IP Logged
installing remote start in a 2010 ford sporttrak, if anyone can please help me with a wiring diagram for this 2010 sporttrak.thank you...
mpe235
Copper -
Posted: November 22, 2010 at 5:36 AM / IP Logged
Remote Start |
WIRE |
COLOR |
POLARITY |
LOCATION |
Battery |
VIOLET/RED |
IGNITION SWITCH HARNESS |
Ignition 1 |
WHITE/ ORANGE |
Accessory 1 |
VIOLET/GREEN |
Starter 1 |
BLUE/WHITE |
Anti-Theft Type |
FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER |
Anti-Theft Descript |
THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER |
Key Sense |
BLUE/GRAY |
Neutral Safety |
BLUE/WHITE |
AT SMART JUNCTION BOX UNDER DRIVER SIDE DASH |
ALSO AT IGNITION SWITCH HARNESS |
Tachometer |
GREEN/ BLUE |
(AC) |
AT PCM MODULE ON PASSENGER SIDE FIREWALL |
Speed Sense |
VIOLET/ORANGE |
(AC) |
Parking Lights |
BLUE/WHITE |
IN HARNESS IN DRIVER KICKPANEL |
Low Crr. Pk Lights |
GRAY |
AT VEHICLE HEADLIGHT SWITCH |
MUST ISOLATE FROM THE SWITCH WITH A RELAY |
Brake Lights |
VIOLET/WHITE |
AT SWITCH ABOVE PEDAL |
Reverse Lights |
BROWN / BLUE |
AT SMART JUNCTION BOX IN DRIVER KICKPANEL |
Horn |
BLUE/WHITE |
IN HARNESS AT STEERING COLUMN |
THERE ARE SEVERAL SMALL GAUGE BLUE/WHITE WIRES, BE SURE TO TEST |
Anti Theft RX |
VIOLET/GRAY |
AT PATS MODULE |
Anti Theft TX |
YELLOW/ORANGE |
AT PATS MODULE |
Nissan Master Tech.
mpe235
Copper -
Posted: November 22, 2010 at 5:38 AM / IP Logged
WIRE |
COLOR |
POLARITY |
LOCATION |
Power Unlock |
VIOLET/GRAY |
PowerLock |
GRAY / YELLOW |
Driver Mtr Unlock |
BLUE/GREEN |
(REV) |
AT MOTOR IN DOOR |
Driver Mtr Lock |
GRAY/BROWN |
(REV) |
AT MOTOR IN DOOR |
Pas Mtr Unlock |
VIOLET/GRAY |
(REV) |
AT MOTOR IN DOOR |
Pas Mtr Lock |
GRAY/BROWN |
(REV) |
AT MOTOR IN DOOR |
Nissan Master Tech.
Saturday, April 20, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
