command starter
greengiant14
Member - Posts: 6
Posted: October 28, 2011 at 4:20 PM / IP Logged
Hello All,
I can't seem to find a forum for the command starters, or maybe there isn't one.
I have a couple quick questions.
I installed an command start in my 92 ford ranger, when i start it with the command start, the battery gauge only comes up to about 11 - 12 volts. I don't think it charging the battery. When i turn the key ahead(still under command start at this point) the battery gauge comes up to where it normally runs. Anyone know why it would be doing this?
Another thing is the blower motor, it doesn't come on when the truck starts until i turn the key ahead. I have done some reading on this subject and found i need to put a relay in to connect 3 different wires for the power the blower needs. Is there a certain type of relay or are they all pretty much the same? And once this is done will it solve my Charging Issue?
Regards,
Jody
2007 Grand Caravan 3.3L - 52000 KM
1992 Ford Ranger 4.0 L - 296000 KM
Posted: October 29, 2011 at 1:48 AM / IP Logged
You will need three relays if three wires are to be connected unless all three normally join together. Use 5 pin Bosch/Tycho type, available from auto parts stores.
Posted: October 29, 2011 at 1:51 AM / IP Logged
Some Command start listings are in the downloads/Manuals section here, I just entered "Command Start" in the right hand search box.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
