2011 town and country remote start
tbird2340
Copper - Posts: 363
Posted: December 15, 2011 at 1:59 PM / IP Logged
I'm installing a Compustar 6200 Brain with the RF-P1B-SS and BLADE-AL bypass..
I have the wiring diagram for both the vehicle and for the BLADE-AL.. I'm a little confused as to what all I need to connect..
Is all that I need to hook up what is shown below from the BLADE-AL guide?
2011 town and country remote start -- posted image.
According to it all that I would be hooking up to the actual vehicle would be the IGN, the CANH, the CANL, and the parking light wire..
Other than that I would think I just need to hook up my (2) 12V and ground to my brain.. Is that right?
Sorry but it's been a few years since I've done installs and I've never used a Blade.
Appreciate any help!
tedmond
Gold - Posts: 4,610
Posted: December 15, 2011 at 2:18 PM / IP Logged
has the blade-al been flashed for your specific vehicle?
never done a 2011 TC but based off the wiring the blade-al will take care of everything for you.
just the power/grounds from the 6pin main harness to the compustar is needed, and follow wiring diagram for blade-al
Ted
Compustar Expert
Platinum - Posts: 7,783
Posted: December 15, 2011 at 2:21 PM / IP Logged
Pretty much.  From the CM6200 the two Red +12V power, Black to Chassis Ground, Gray/Black to Hood Pin, and White to Horn ( optional ).
Here are some pics :
You can fuse down the CM6200 power to 10 Amps ( each ) and connect to this wire :
tbird2340
Copper - Posts: 363
Posted: December 15, 2011 at 2:38 PM / IP Logged
Thanks a lot for these pics.. Where are the pictures in the first two pictures in relation to vehicle location?
I can't believe that's all you have to hook up! That's the least amount of wires I've ever had to do.. Awesome!
2011 town and country remote start -- posted image. 2011 town and country remote start -- posted image.
metz35
Copper - Posts: 458
Posted: December 15, 2011 at 2:50 PM / IP Logged
one of my favorite vehicles.... its like a slam dunk in basketball :)
Posted: December 15, 2011 at 3:01 PM / IP Logged
The Ignition and CAN wires are under the drivers dash coming down from the ignition switch.  Here is another picture that is further back ( and shows the Horn wire ) for a better perspective.
When you remove the lower dash panel ( 3 torx screws ) and the metal knee plate ( 4 torx screws ), it is pretty easy to find.
The Parking Light wire picture was taken looking up behind the switch.  The vehicle has a lot of room to work & place the R/S unit.  Like metz35 said, "a real slam dunk"!
tbird2340
Copper - Posts: 363
Posted: December 25, 2011 at 5:56 PM / IP Logged
Anyone know if it would be OK to use a 1N4003 diode? The picture shows a 1N4001 but I actually have a 1N4003 in hand..
Ween
Platinum - Posts: 1,366
Posted: December 25, 2011 at 7:21 PM / IP Logged
a 1N4003 will work just fine.
tbird2340
Copper - Posts: 363
Posted: December 26, 2011 at 7:50 PM / IP Logged
Thanks for all the help. Got this done tonight and it was simple as everyone said! :)
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
