9 wire hookup to amplifier
brandon12494
Member - Posts: 15
Posted: March 01, 2012 at 1:18 PM / IP Logged
I'm trying to hookup stinger 9-wire cable from my speakers positive and negative charged wires to my 4 channel amplifier. I crimped the wires together and then ran to the positive and negative side of my 4 channel amp but nothing comes out of the speakers. I'm not sure if I crimped the wires to the wrong harness behind my stereo or not. Please help!! Thanks in advance.
itsyuk
Silver - Posts: 505
Posted: March 01, 2012 at 3:24 PM / IP Logged
you need to tell us the stereo and model number and the amp and model number and probably the the speaker.
which color of wire went to what terminal etc....
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
brandon12494
Member - Posts: 15
Posted: March 01, 2012 at 3:42 PM / IP Logged
Well it's a pioneer stereo, I'll have check the model number and it's an alpine -300 amp and I connected the wires from the 9-wire to the speaker harness that goes to my speaker wires not the one that plugs into the back of the stereo. Thanks
DYohn
Moderator - Posts: 10,741
Posted: March 01, 2012 at 5:27 PM / IP Logged
What "9-wire speaker harness"?  Is this part of the vehicle?  Is it an aftermarket part?  If so, what's the part number?  What vehicle?  Are you trying to use the factory speakers?  Does the vehicle have a factory amp?
co_ne_dub
Copper - Posts: 80
Posted: March 01, 2012 at 8:20 PM / IP Logged
I think he means speed cable.
OP you need to provide us with more information regarding your vehicle, equipment used, what you have done so far.
From your posts I can guess that you have run the 9wire cable to the car-side harness, correct? You have verified that you have power to the amp and the remote wire?
soundnsecurity
Gold - Posts: 2,711
Posted: March 02, 2012 at 8:53 AM / IP Logged
did you disconnect the speaker wires from the back of the radio? you cant have the amp and the radio connected to the speakers at the same time, you have to disconnect the speakers from the back of the radio and hook up the 9 wire cable to the side of the speaker wires coming from the car.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
