new speakers, new amp, sounds horrible.
brandon12494
Member - Posts: 15
Posted: March 04, 2012 at 1:11 AM / IP Logged
I have just recently purchased 6.5 inch polk audio 6501 component speakers for the front of my Subaru impreza WRX and polk audio 5.25 inch DB521 coaxial speakers for the back of my car powered by a 4 channel MRP-300 alpine amplifier. I also have a pioneer DEH-4300UB stereo deck. So i used the 9 wire speed cable and hooked it to the back of my harness and had the other end hooked to the amplifier, and i made sure all the crimps were snug and what not, but the sound it just horrible. I can hear the instrustments but can barely hear the voice of the singer. I dont know if its the polarity or whats going on. Someone please help! Thanks in advance!
itsyuk
Silver - Posts: 505
Posted: March 04, 2012 at 1:51 AM / IP Logged
it sounds like maybe you used the woofer outputs as inputs on your speaker crossover.
the radio dont have some silly karaoke mode does it?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Platinum - Posts: 13,674
Posted: March 04, 2012 at 9:33 AM / IP Logged
If you start the engine, can you hear it through the speakers?
brandon12494
Member - Posts: 15
Posted: March 04, 2012 at 11:36 AM / IP Logged
for my woofer all i did was run the wire that they gave me with the speakers to the cross over and the wire from the tweeter to the crossover and then ran speaker wire from the 9 speed wire to the crossover. And to tell you the truth i havent really tried to run the car while the speakers are playing but i dont know why that would make a difference.
brandon12494
Member - Posts: 15
Posted: March 04, 2012 at 11:43 AM / IP Logged
well i ran the wire that came with the speakers from the woofer to the crossover and the tweeter wire from the tweeter to the crossover and then i ran speaker wire from the 9 speed wire to the crossover as well but it just sounds like crap. I honestly havent turned on the car at the same time as the speakers but i dont know why it would make a difference in the sound. thanks in advance!
soundnsecurity
Gold - Posts: 2,711
Posted: March 04, 2012 at 1:05 PM / IP Logged
have you played with the settings on the pioneer? maybe a different eq setting would sound better. check to make sure your crossover on the amp is set to HPF not LPF
brandon12494
Member - Posts: 15
Posted: March 04, 2012 at 1:42 PM / IP Logged
Everything is set to how you said so I have no idea and it's really irritating me. Could it be the polarity?
Posted: March 04, 2012 at 3:13 PM / IP Logged
I think I know the answer to the question, and I think I know the solution to your problem.  But I need only one thing from you.
itsyuk
Silver - Posts: 505
Posted: March 04, 2012 at 3:17 PM / IP Logged
so you bridged the alpine to run this pair of speakers or is there more to this system than what you are telling us?
which outputs run from the pio to the alp?
yuk
soundnsecurity
Gold - Posts: 2,711
Posted: March 04, 2012 at 6:40 PM / IP Logged
you did disconnect the speaker outputs on the back of the radio from the speakers right? the alpine amp should be the only thing connected to your speakers.
Page of 4
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
