viper 5902
tegguy
Copper - Posts: 155
Posted: January 31, 2013 at 1:01 PM / IP Logged
I guess maybe I should be tied into the coil (pnk) wire for the ignition since it will be +12V whenever the key is on cranking or not.
Posted: January 31, 2013 at 2:06 PM / IP Logged
ACC hot on ACC, off when cranking on when run.
IGN = off on ACC, hot on IGN, hot on crank hot on engine run.
tegguy
Copper - Posts: 155
Posted: January 31, 2013 at 2:09 PM / IP Logged
Thanks Howie so any idea if I should be tapped into Pink or Orange? I'm thinking it should be the coil one since that would need to be hot for the car to start.
Posted: January 31, 2013 at 2:37 PM / IP Logged
Exactly.
tegguy
Copper - Posts: 155
Posted: January 31, 2013 at 2:48 PM / IP Logged
Thanks I'll look into it this weekend
tegguy
Copper - Posts: 155
Posted: February 07, 2013 at 6:40 AM / IP Logged
I just thought I'd post a follow up. Howie was correct the wire I was using was drooping to 0 when cranking. I switched the wire over to the coil wire and the starter kill now works.
Page of 3
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
