viper 5704v on 94 lexus
smokeman1
Platinum - Posts: 1,588
Posted: January 01, 2014 at 1:06 PM / IP Logged
Do you have the parking lights connected? You stated the module makes ABOUT 8 clicks. Need to know exactly how many.
The parking lights flashing the number of clicks works better.
Also need to connect the H3/2 RED / white to a constant 12 volt source. This is the input for the H3/7 pink/white output to ignition 2.
See video: http://youtu.be/uq1ETQxMp7M
lowriderman234
Member - Posts: 12
Posted: January 01, 2014 at 10:45 PM / IP Logged
Yes I've tried the key on key off and holding down the control center button but nothing happens.. So I need a total of 3 wires hooked up to a constant 12v? I have only two constant 12v and it's white and WHITE/ red. The alarm part is hooked up to there, so would 3 more wires there be dangerous?
smokeman1
Posted: January 02, 2014 at 6:28 AM / IP Logged
Is your car Automatic or manual?
Yes. H3/2,6, and 9 need to be connected to a constant 12 volt source. If you have two 12 volt wires, just split all of your connection between the two.
Go to the download section and get the Viper 5701 install manual. On page 60 there is a better explanation of how to get into the menus and make changes.
Take the H2/6 Green wire and put it to a chassis ground. This is the (-) Neg door trigger. The brain needs to see it along with the key ON/OFF to get into the menus. It will take a number of tries for you to get it as it can be tricky.
