2013 toyota tacoma remote start
spartacus12.lg
Member - Posts: 38
Posted: August 05, 2014 at 10:06 PM / IP Logged
got it working thanks for all your help. i really appreciate it.
spartacus12
spartacus12.lg
Member - Posts: 38
Posted: August 05, 2014 at 10:32 PM / IP Logged
went over all my wiring and it was cut wire that was the problem. fixed that and everything worked great. there is a whooshing/sucking sound when you turn off the truck but on another post they said this was normal. is this true? thanks for all your help.
spartacus12
spartacus12.lg
Member - Posts: 38
Posted: August 06, 2014 at 6:56 PM / IP Logged
hey kreg357 sorry to bother you again but i got everything working and tested it several times. it worked great then i put everything together and now it just cranks and wont start. what could be causing this.
spartacus12
Platinum - Posts: 7,783
Posted: August 06, 2014 at 7:38 PM / IP Logged
My gut instinct would be to review anything done after it worked last.  In this case securing / neatening-up and putting everything back together would be at the top of my check list.  This doesn't happen often if you position / cut to length / solder and insulate each connection.
There would be a few areas of higher probability.
First would be the transponder bypass ( PKALL ).  You can see if this is your problem by unplugging the power to the bypass module and holding a key at the ignition switch.  If the truck starts, check the bypass module and all its' connections.
Second would be a blown fuse going to the R/S unit.  I have seen where the slightly exposed metal tips at the fuse body can be inadvertently  be bumped against vehicle metal frame, blowing the fuse.  I always wrap the exposed fuse with a layer or two of Scotch Super 33+ to prevent this.  If all the fuses test good, then verify good +12V power at the R/S itself at all the +12V inputs, in case of a wiring connection problem or vehicle blown fuse.
Third is a problem with the Tach wire or connection.  Some R/S units that are programmed for Tach Mode and then loose the signal give similar symptoms.
Lastly would be an ignition wire connection problem.  As mentioned, this should not happen to a soldered-in R/S installation, but...
spartacus12.lg
Member - Posts: 38
Posted: August 06, 2014 at 8:12 PM / IP Logged
this is what i did i disoconnected the pkall tried to start it with the key and it did not start so i then disconnected the alarm and tried to start it again with the key this time it started but now when i connected the alarm brain again now it wont even crank im totally frustrated with this thing. thanks for your quick response will check all wire connections again.
spartacus12
Posted: August 06, 2014 at 8:27 PM / IP Logged
Be cautious with what you disconnect.  Remember that if you cut the Tacoma's Starter1 wire to make the 5303 H/1 Purple and H/2 Green connections, it will prevent a regular key start if the thick wire H connector is unplugged from the 5303.  Similar situation with the PKALL and its' Connector 3.  There you opened the vehicles IMI wire.  The relay that supplies the N.C. connection ( and allows a regular key start ) is inside the module(s).
spartacus12.lg
Member - Posts: 38
Posted: August 06, 2014 at 8:30 PM / IP Logged
ok thanks i will go over all the connections one more time but like i said now it doesnt even crank with the remote start so ill just go over what you said and hopefully it will work. thank you very much.
spartacus12
spartacus12.lg
Member - Posts: 38
Posted: August 07, 2014 at 1:45 PM / IP Logged
hey kreg357 thanks for all your help. the problem was a bad wire connection at the ignition wiring harness. and now all i have to say is solder, solder, solder.
again thanks
and now i move on the tackling the active restraint system on my van headrest.
spartacus12
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
