negative to positive
ccaudio
Copper - Posts: 52
Posted: May 09, 2015 at 10:06 AM / IP Logged Link to Post Post Reply Quote ccaudio
I am installing a remote start on a 94 chevy g20. Can I use a relay that only has pins. 86. 30. 85. And 87a. To convert a negative to positive for the locks. The relays I have don't have pin 87.
Posted: May 09, 2015 at 11:11 AM / IP Logged Link to Post Post Reply Quote howie ll
You need a 4 or 5 pin relay with 87. 87a denotes NC or normally closed,i.e. it's connected to 30 until the relay is energised, that's the opposite of what you want.
DEI 451 double relay module is what you want, if you're using DEI product it plugs straight in.
icearrow6
Copper - Posts: 497
Posted: May 21, 2015 at 12:29 PM / IP Logged Link to Post Post Reply Quote icearrow6
Use one for each direction (lock/unlock)
https://www.the12volt.com/relays/relaydiagram8.html
Posted: May 21, 2015 at 12:31 PM / IP Logged Link to Post Post Reply Quote howie ll
IceArrow....oops! Yes 2 relays though I did specify a single 451.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
