2011 Silverado Remote Start Pictorial
smokeman1
Platinum - Posts: 1,588
Posted: September 06, 2015 at 5:54 PM / IP Logged Link to Post Post Reply Quote smokeman1
2011 Chevy Silverado Remote Start install. Truck has power locks and a Factory Alarm.
Installed a Viper 4204 with a DB-ALL using the D2D method. Also used the RFLCHGM transponder loop.
This was a real easy install. The DB-ALL did TACH and brake signal. It also did the hood signal since there was a factory alarm.
Power, Ground, Horn, Ignition, Accessory, and one connection at the OBD were the only wires connected.
DB-ALL and the RFLCHGM programed 1st time no problems.
2011 Silverado Remote Start Pictorial - Last Post -- posted image.
Lower Dash Panel. Two screws and one 10mm bolt on bottom, then three clips hold it on.
Fuse panel, fuse box, and back of fuse box for 12 volt connection.
Headlight panel held on with five clips and Parking light wire.
Under dash area. Fair amount of room.
Tilt Wheel Lever pulls out to remove lower steering cover for access to Ignition and transponder connectors.
Ignition Connector and Transponder connector
Ignition Wire(Pink), and Accessory Wire,(Brown)
RFLCHGM cable loop around Key cylinder. Tightened with a small zip tie.
All tucked away.
racerjames76
Silver - Posts: 581
Posted: September 08, 2015 at 7:50 AM / IP Logged Link to Post Post Reply Quote racerjames76
Good write up. I am only replying because I just realized Saturday that the distribution block was removable allowing easier access to the large RED / black RED / white power wires. I have been accessing them precariously through the subdash opening...PITA! LOL Oh well 2011 Silverado Remote Start Pictorial - Last Post -- posted image.
To master and control electricity is perfection. *evil laugh*
drumm14
Member - Posts: 9
Posted: September 16, 2015 at 11:49 AM / IP Logged Link to Post Post Reply Quote drumm14
Did you have factory remote start?
smokeman1
Posted: September 16, 2015 at 8:05 PM / IP Logged Link to Post Post Reply Quote smokeman1
This Silverado did NOT have a factory remote starter
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
