Sub Wiring
ejpristia
Member - Posts: 9
Posted: May 25, 2003 at 2:13 AM / IP Logged
If I have a mono amp and want to run a single sub off of it; would it be better to get a 4 ohm sub or 2 ohm sub?
bberman1
Gold - Posts: 2,314
Posted: May 25, 2003 at 9:44 AM / IP Logged
We need to know the model of the amp in order to tell you how many ohms the sub should be, and how to wire it. And is the sub DVC or SVC (dual voice coil or single voice coil)
ejpristia
Member - Posts: 9
Posted: May 25, 2003 at 11:35 AM / IP Logged
I don't know what amp I am going to use, but I want to hook it up in 2 ohm. The sub is a dual voice coil. I also need to know how to wire up the sub.
luxuryrules
Copper - Posts: 102
Posted: May 25, 2003 at 12:44 PM / IP Logged
What kind of sub, and do you know the resistance?  If it's 4 Ohms per coil, we can tell you how to wire it at 2 Ohms.
Start another thread asking for reccos on what kind of amp to use.  I personally am biased towards Alpine and Lanzar, but the other guys on these boards are professionals and you'll want to see what they have to say.  Depending on what kind of sub you have and what the resistance is rated at, you'll be looking at either a 2 channel (one channel for each voice coil) or a mono (one channel with both coils in parallel).
wvsquirrel
Gold - Posts: 1,237
Posted: May 25, 2003 at 5:34 PM / IP Logged
Ok, you said you are getting a mono amp (that will be 2ohm stable) and the sub will be a DVC. Regardless of the manufacturer, to run a single DVC in 2ohms you will want to get a 4ohm DVC sub and wire it in parallel.
Sub Wiring - Last Post -- posted image.
Also, make sure when choosing an amp and sub to match the RMS ratings. With DVC's, make sure you are matching the total RMS rating of the sub, not just each voice coil. In your case, make sure to match the RMS ratings at 2ohms, since that's what you are planning at running at.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
