04 Town and country Remote start rear defroster?
jcharley
Copper - Posts: 55
Posted: January 30, 2016 at 8:06 AM / IP Logged Link to Post Post Reply Quote jcharley
Yes it did open
jcharley
Copper - Posts: 55
Posted: January 30, 2016 at 8:45 AM / IP Logged Link to Post Post Reply Quote jcharley
I'm not sure what else to test. I've checked the R/S worrying harness for continuity and the wire is good.
Platinum - Posts: 7,783
Posted: January 30, 2016 at 9:03 AM / IP Logged Link to Post Post Reply Quote kreg357
The bypass module is doing its' job.  It's not getting the signal from the R/S to open the right sliding door.  I'm not familiar with the R/S unit you are using but perhaps there is a special sequence you must follow to get that Channel to output?
jcharley
Copper - Posts: 55
Posted: January 30, 2016 at 9:12 AM / IP Logged Link to Post Post Reply Quote jcharley
Yeah I've tried several times to reprogram the remote. Maybe I'm doing something wrong. I'll keep messing with the remote. How do I test the output on the R/S to see if it's putting out the 300ma?
jcharley
Copper - Posts: 55
Posted: January 30, 2016 at 9:14 AM / IP Logged Link to Post Post Reply Quote jcharley
jcharley
Copper - Posts: 55
Posted: January 30, 2016 at 9:15 AM / IP Logged Link to Post Post Reply Quote jcharley
Posted: January 30, 2016 at 9:34 AM / IP Logged Link to Post Post Reply Quote kreg357
Use a Digital Multi Meter set to 20V DC.  Connect the Red test lead to +12V constant.  Connect the Black test lead to the R/S Channel output wire.  The DMM will briefly ( 0.8 sec ? ) show +12V when the output is present.
jcharley
Copper - Posts: 55
Posted: January 30, 2016 at 11:02 AM / IP Logged Link to Post Post Reply Quote jcharley
Hey thanks for the help, I was able to reset the remote and program it from a blank state and all works now,   just gotta find that defrost wire. And if you don't mind how do I test to make sure the defrost wire is correct before I hook into it?
Posted: January 30, 2016 at 11:11 AM / IP Logged Link to Post Post Reply Quote kreg357
I can't find any specific info on the Rear Defrost wire.  MSCGUY's info on it is probably accurate.  You would be
looking for a 12 to 14 gauge wire in the DKP area in the harness that goes into the door sill and continues to the
rear of the minivan.  I this case you are looking for a +12V presence on that wire when the Rear Defroster is ON.
DMM setup is 20V DC.  Black test lead to chassis ground.  Red test lead to suspect wire.  The DMM will read
+12V when the Defroster is ON and 0V when OFF.  Toggle it a few time to verify.
This is a high current circuit so a fused 30/40 Amp SPDT relay is required.
mscguy
Copper - Posts: 212
Posted: January 30, 2016 at 12:51 PM / IP Logged Link to Post Post Reply Quote mscguy
Whatever wire I said earlier is what alldata shows. It only does rear window though. Not mirrors.
Kreg did a pictorial on a caravan and it will be a similar wire.
Page of 4
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
