2002 Toyota Sequoia reverse signal wire
joeydmendoza
Posted: August 11, 2016 at 2:42 PM / IP Logged Link to Post Post Reply Quote joeydmendoza
Hi. I am installing an aftermarket pioneer deck with backup camera. I need to see if someone can help me locate the reverse signal wire so that when I' put the car in reverse the rear camera will display on the pioneer unit. I very much appreciate some help.
Jdm
lurch228
Silver - Posts: 1,338
Posted: August 12, 2016 at 5:44 PM / IP Logged Link to Post Post Reply Quote lurch228
Check for a Red wire with black trace possibly with silver dots in the trace. Either in relay/fuse box or Black Plug drivers kick panel. Others say it can be found on the passenger side kick pannel above glove box, and behind drivers seat coming from center.
There are Pics (need Pic #4) here but need to be a member to view them. http://www.tundrasolutions.com/forums/1gen-sequoia/45739-sequoia-avic-d3-install-pics-speed/#post462142
Posted: August 14, 2016 at 7:35 AM / IP Logged Link to Post Post Reply Quote howie ll
Or go old school, check the wiring at the plug to the light cluster and follow forward or simply wire it there. You've must have pulled down the back end already to wire the camera feed.
lurch228
Posted: August 14, 2016 at 3:46 PM / IP Logged Link to Post Post Reply Quote lurch228
Don't think he has got that far yet still trying to find it up front. With the info he has been given he should be able to find it.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
