CS310I command start troubleshoot
blaster45
Posted: August 30, 2016 at 5:30 PM / IP Logged Link to Post Post Reply Quote blaster45
I have the cs310i in my 2001 duramax 2500 and the in line 30amp fuse keeps blowing. I have checked the wiring over and can't see any problems with shorting but anytime I go to put the fuse in, it blows. It's worked before but I tried one day an found the fuse blown. Is there anytime else to check?
lurch228
Silver - Posts: 1,338
Posted: August 31, 2016 at 4:34 AM / IP Logged Link to Post Post Reply Quote lurch228
Sounds like a stuck internal relay, probably the ignition or starter output.
blaster45
Posted: August 31, 2016 at 4:42 PM / IP Logged Link to Post Post Reply Quote blaster45
I just checked the ignition and starter relay and both work good. Open an close fine. Could it be the ignition switch?
lurch228
Posted: August 31, 2016 at 8:44 PM / IP Logged Link to Post Post Reply Quote lurch228
Would have to be a short to ground typically if it's blowing a 30A fuse. Is it the RED or the RED / Black that is blowing?
Try unplugging the heavy gauge wire plug before replacing the fuse, then plug it back in once you have replaced the fuse!
blaster45
Posted: August 31, 2016 at 9:41 PM / IP Logged Link to Post Post Reply Quote blaster45
It is the red one that kept blowing. But I reset the box today and plugged the fuse in an i got power through without a blown fuse. Just have to fix the hoodpin switch and I think it might work.
lurch228
Posted: August 31, 2016 at 9:50 PM / IP Logged Link to Post Post Reply Quote lurch228
sounds like the brain got stuck.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
