2011 Altima Viper RS DBALL2
97f150ext
Copper - Posts: 104
Posted: November 15, 2016 at 7:17 PM / IP Logged Link to Post Post Reply Quote 97f150ext
2011 Altima
Viper 4706v
DBALL2
THNISS3 rev 3 harness
D2D
Flashed module on Directechs this morning.
Programmed to car, lock and unlock work from Viper. On first test of remote start, car started. Now on remote start, car does not attempt to start, and warning light on dash with the key flashes. I reprgrammed module, lock and unlock still work, but no remote start.
What should I check? This is my wife's car, so I have access to anytime. I have another DBALL2, but I'm not sure that is the problem yet.
Any ideas?
97f150ext
Copper - Posts: 104
Posted: November 16, 2016 at 12:49 PM / IP Logged Link to Post Post Reply Quote 97f150ext
I just spoke with someone via chat at Directechs.
Their instruction was to turn the engine checking to "off" and to set the crank time to 2 seconds.
I inquired as to why the engine checking should be off, and the response was "because of pts, it gives a more consistent start."
Going to try this tonight and see what happens. I will post with updates.
97f150ext
Copper - Posts: 104
Posted: November 17, 2016 at 8:15 AM / IP Logged Link to Post Post Reply Quote 97f150ext
The directions from the good people at DEI solved my issue.
I made the changes they recommended, and the car now starts every time.
I wanted to post this in the event that someone else ran in to a similar issue.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
