not working APS57E - 2004 dodge ram 1500
04dodgeram1500
Posted: June 01, 2017 at 2:26 PM / IP Logged Link to Post Post Reply Quote 04dodgeram1500
sorry about caps, it was a copy/paste
aps 57e - 2004 dodge ram 1500 4.7
no existing factory alarm system that i am aware of.
tried the key in tumbler twice and only unlocks drivers door.
14 pin main harness
green/orange-tachometer – not connected
green/yellow-glow plug – not connected (not diesel)
dk blue – trunk release – not connected
brown/black (+) inhibit brake switch – white/tan connected at
      brake switch
brown (–) inhibit brake switch – not connected
grey (–) inhibit neutral start switch – not connected
black/yellow (–) pulse during crank output – not connected
black/red (-) pulse after shutdown output – not connected
black/blue (-) pulse before start output – not connected
black/lt green (-) pulse after start output – not connected
lt blue (-) ground while running output – not connected
grey/black (-) inhibit shutdown hood sw – connected and
checked working properly (not grounding to frame)
black/white (-) horn output – dark green/purple (steering
column) working properly horn honks when lock/unlock
6 pin power start harness
blue – ignition 1 (+) connected pink/white
red/white battery 1 (+) connected red wire #1
green – ignition 2 (+) connected pink/green
purple accessory (+) connected to blue wire (ac blower)
red battery 2 (+) connected red wire #2
yellow starter output connected yellow wire starter
4 pin 2nd main harness
black chassis ground (-) grounded to chassis
white/red parking light input (-) grounded to chassis
yellow/black to controlling alarms ignition input – not
connected
white – parking light output (-) white/light green at headlight
switch with 330 ohm
(parking lights are working properly both by themselves and via the remote start. blinking with lock and unlock)
2 pin door lock output harness
red – door lock connected single wire system with correct
resistor
green – door unlock output connected single wire system with correct resistor.
(door lock and unlock working properly with remote control)
the remote start is not working properly when i press the trunk button twice in 5 seconds. what happens is the parking lights flash 7 times.
does it need to be programmed?
do i have something wired incorrectly?
is there something else that must be hooked up that isn't?
thanks in advance.
04dodgeram1500
Posted: June 01, 2017 at 5:15 PM / IP Logged Link to Post Post Reply Quote 04dodgeram1500
Hooked up the tach wire to the negative on the number 1 coil pack. Taught the starter how to "learn the tach" boom, done. Figured it out.
